Interior Advice please
Old Jun 20, 2012 | 06:24 AM
jonrms's Avatar
Default Interior Advice please
I am swapping out one interior for another on the same model of S type.. only problem is the colour codes.. ok no big deal as it appears I will have to just remove the upper parts of the door cards in the front and the centre concil and glove box etc... lower bits..
any advice... all the seats are being swapped out as well.. thats the reason for it... thanks.
ps Tips are also very helpfull and will be appreciated
Old Jun 20, 2012 | 09:01 AM
PeteMC's Avatar
Don't really understand what you're asking mate? If you have a donor car surely you just take everything removable out of that and put it in your car the same way it came out?
Old Jun 20, 2012 | 10:04 AM
JOsworth's Avatar
Get a bunch of zip-loc baggies and a digital camera. Take a bag and tag it for each component, then place all the clips and fasteners into the bag. Take many pictures of each thing you take apart, including before pictures. This will help you remember all the little things you will forget when you go to put it back together...
Also, take your time... don't force things.. plastic likes to break....
Old Jun 21, 2012 | 01:42 AM
jonrms's Avatar
sorry I wasnt clear, I was asking.. are there any hidden bolts, nuts clips I should be aware of.
last night I only had the chance to remove the drivers door panel and fix the central locking on the donor car.. so I havnt done anything more than that. but with seats, the under belly of the dash, the rear shelf etc.. are there anything I need to be aware of when removing them.
I know with nissan (300zx) and my porche 911 everything was hidden.. you think you were able to remove bits then found that there was a torx head or screw you missed.
Everything requires some force.. take that door panel for instance. First door I ever and I mean EVER worked on that had 2 screws only!!!! plus the rest just easy plastic clips...
Old Jun 21, 2012 | 08:35 AM
Originally Posted by JOsworth
Get a bunch of zip-loc baggies and a digital camera. Take a bag and tag it for each component, then place all the clips and fasteners into the bag. Take many pictures of each thing you take apart, including before pictures. This will help you remember all the little things you will forget when you go to put it back together.........
There's good advice from someone else who has done a long term restoration in the past!
Is this the kind of info you're after?
JTIS - 2000 S-Type Front Door Trim Panel.pdf
JTIS - 2000 S-Type Front Seat.pdf
If so, the JTIS is going to be your new best friend. You can download it from the FAQ's.
Old Jun 21, 2012 | 10:14 AM
jonrms's Avatar
Thanks Graham I didnt even think of looking at my JTIS.... was also looking for any tips.... or tricks... you only learn so much from these things dont you.... and advice is sometimes priceless.
Old Jun 21, 2012 | 12:31 PM
tbird6's Avatar
Another vote to get the JTIS. It will help a lot.
Old Jun 21, 2012 | 08:28 PM
Amadauss's Avatar
this tool comes in very handy. You can get it almost anywhere.
Old Jun 22, 2012 | 07:38 AM
JOsworth's Avatar
Also, get a set of these.... Will help to release clips yet not damage the finish...
One of the most used tools in my set..
Cheap Harbor Freight Set
More expensive Summit Racing set
Have a set of both.. Both work fine. The Summit Racing set is better made, but the cheap set from Harbor Freight has not failed yet..
Old Jun 22, 2012 | 03:16 PM
usajay38's Avatar
i was thinking of replacing my front seats
42Ajd
Dec 30, 2015 09:45 AM
42Ajd
Sep 21, 2015 07:37 PM
John Fox
Sep 12, 2015 12:20 PM
1964Daimler
Sep 9, 2015 11:28 AM
King Charles
Sep 3, 2015 12:40 AM
