JAGUAR S TYPE R Zimmerman Brake Rotor
Old Apr 13, 2023 | 07:10 PM
turkay's Avatar
Default JAGUAR S TYPE R Zimmerman Brake Rotor
Hello,
Quick questione will they fit my Jaguar S TYPE R from 2004 with VIN SAJAA03S741N07607 ?
From what I have seen the only thing that does not match is the outer diameter and height.
Old Apr 13, 2023 | 08:35 PM
xalty's Avatar
365 is correct
Old Apr 14, 2023 | 06:53 AM
turkay's Avatar
Originally Posted by xalty
365 is correct
So the Zimmerman rotors eont’t fit the front of the car?
Old Apr 14, 2023 | 07:11 AM
xalty's Avatar
they are for facelift with 1 piston slider
unfortunately your car has garbage brembos
Old Apr 14, 2023 | 07:13 AM
turkay's Avatar
Damn
Any way to find perforated for my jaguar? i need to service rhe brake rotors since they are really old and I decided to throw in the extra buck and get her perforated rotors.
Old Apr 16, 2023 | 05:02 PM
elDariusVargas's Avatar
werent the rotors for the Ate calipers 355mm?
Old Apr 17, 2023 | 03:45 PM
The Voices's Avatar
First image is the 365mm discs for the Brembo setup, the second image is the 355mm ones for the later ATE setup.
Old Apr 17, 2023 | 06:45 PM
ohh my bad. I see now
Old Apr 17, 2023 | 08:05 PM
turkay's Avatar
Why are they garbage though?
Old Apr 18, 2023 | 04:20 PM
The Voices's Avatar
General opinion is that the earlier Brembo brake setup, whilst very pretty, does not perform as well as the later ATE setup.
Suggested reasons vary, but one line of reasoning is that the Brembo calipers are not very rigid and flex under heavy use, this can lead to warped discs.
My 2004 XJR has the Brembos, my 2006 STR has the ATE's, all I can say is that with new discs on both, EBC yellow stuff pads and fresh fluid, the ATE's have much better pedal feel and seem to offer more stopping power ?
Old Apr 19, 2023 | 03:09 AM
jya's Avatar
jya
I've lost count of the posts regarding the two brake brands.
I wouldn't call any high performance Brembo brake 'garbage'.
The only real way to determine which one would outperform the other? Find two near identical cars with identical tyres, identical age tyres, identical fuel in each cars tank, identical brake fluid, identical brake hoses, identical condition dampers, identical condition springs, identical condition wishbones, original Brembo rotors in the Brembo brake car and original rotors that came with the ATE car, same driver, same day, same temperature, you get the drift.....
A meaningless exercise as they're both premium set up's. I would have liked to have been a fly on the wall at the meeting when Jaguar decided to make the change.
They're a bit noisy when cold sometimes but I'd have the Brembo's any day.
Old Apr 19, 2023 | 06:30 AM
If we are discussing brakes, guys i need help on one of my issues with my ate calipers. They have a strange wear angle on the inside, both sides.
here is my topic maybe someone has the same experience. I have pictures there
thank you
https://www.jaguarforums.com/forum/s...brakes-264263/
Old Apr 19, 2023 | 08:13 AM
xalty's Avatar
because they’re complete garbage and they suck
no contact surface
unvented rears
terrible pedal feel
Old Apr 19, 2023 | 09:55 AM
JagV8's Avatar
I don't have a terrible pedal feel with mine & don't care whether the rears are vented or not!
Old Apr 19, 2023 | 10:08 AM
no contact surface
unvented rears
terrible pedal feel
i have the ate ones on a prefacelift 2003 non R. its the same feeling as before the upgrade but they stop quicker.
When i asked on my topic why, people told me it's the system itself. master cyl and abs module are better in the facelift.
The vented rear ones on a 2006+ str are the same like the rear ones on a diesel, or a XF. its just some good working regular brakes.
It would be awesome for someone to fit the brembos calipers on a facelift that comes with the ate calipers... wonder if they would feel better
Old Apr 19, 2023 | 10:16 AM
xalty's Avatar
pedal feel/=/stopping power and brake fade resistance. as a complete package it sucks, the calipers are junk and the rotors are terrible.
i’ve seen it done on an 06 with the mk60 and they threw in the towel immediately. took the knuckles off and went to the 380s
again they flat out suck. even the vanquish with 2 piece rotors and vented rears is beyond terrible.
Old Apr 19, 2023 | 05:00 PM
The Voices's Avatar
My two cars are as close a comparison as I can do in the 'real world' and the ATE's win hands down.
I have been selling Jaguars since 2002 and we used to have a lot of issues with customer complaints with the Brembos warping discs.
Far more qualified people than myself have stated that the calipers are not 'rigid' enough.
When Jaguar swapped over to the ATE setup, they told us it was due to improved braking, not for cost reasons.
Make of that what you will.........................................
Jose
16
Jul 24, 2023 09:58 PM
wouldbeowner
29
Sep 30, 2020 04:58 PM
Arturo Martinez
Jun 16, 2020 07:53 PM
wouldbeowner
Aug 28, 2019 01:14 AM
XJR 308
Dec 14, 2016 04:02 PM
