jaguar voice and bluetooth
Old Jun 17, 2011 | 01:34 AM
yzedf's Avatar
Default jaguar voice and bluetooth
is there a parts list somewhere or a DIY thread? my 2005 has the buttons on wheel and dash but nothing works. tried the search but it didn't help much.
thanks in advance,
chris
Old Jun 17, 2011 | 01:49 AM
JagV8's Avatar
Use Search on each of
bluetooth
BTUM
Jaguar EPC
JEPC
parts
and look closely at the FAQs
But many cars have buttons without the modules etc so yours is likely one.
Old Jun 17, 2011 | 07:28 AM
Toller's Avatar
The key to the presence of either or both options is the microphone, not the buttons.
The microphone is located above the driver's head just to the left of the centerline of the car and slightly forward of where the driver's head would be. It is surface mounted and is about an inch long and half an inch in width and height. If you don't find it there, you don't have these options.
Old Oct 29, 2011 | 11:09 AM
steadicam's Avatar
Default Microphone
He has 2005 if it is like mine the microphone is hidden it is no longer surface mount like previous years.
Old Oct 29, 2011 | 12:28 PM
clubairth1's Avatar
Community Influencer
There was/is two kind of microphones. One integrated in the overhead moonroof control panel. There were many complaints about voice quality.
The external Bluetooth microphone is most common. If you have the integral mic and want to improve the sound you can plug the external version in. Here is the external one.
I have attached the factory instructions for the Blue tooth install. You will find out that it's expensive and complicated but it has been done.
Also Jaguar Voice is related to the Bluetooth but adds additional parts.
Attached Thumbnails jaguar voice and bluetooth-jaguar-bluetooth-microphone.jpg
File Type: pdf
Old Oct 30, 2011 | 10:56 AM
Toller's Avatar
Adding JaguarVoice to an existing nav and BT equipped car will cost about $700 in parts plus about an hour in labor. You'll need to provide your VIN when ordering the parts. As I recall, it was a module and a cable assembly that inserted the module into the car's local area network.
I'm cheap enough that I asked if the car could be restored to it's original state and the JagVoice moved to a new S-Type. I was told "yes"...for the cost of labor to remove and re-install.
D.K
Dec 10, 2023 02:05 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
