Just picked up a V1 detector.
V1 site or ebay...There's all sorts of options if you want to spend the big bucks...
It's nearly useless against laser, once the detector goes off they already have your speed...You'll need laser jammers which is legal in most states to combat laser...In my state, lasers on the highways are almost exclusive...
First, congratulations on choosing the best radar detector available. Bacardi 151 is correct, to combat laser, the Blinder is the top name in laser jamming. In Texas where I currently reside, it is K and Ka band radar that is most common.
Laser is used on approaches to urban areas as it was in Orlando.
I use a Val-1 and have Trapster running on my Droid phone.
The level of speed limit enforcement in East Texas is scary outside urban areas. It's a landmine.
I don't know off the top of my head if V1 makes it's own laser jammer add on but I know it has an interface for a jammer...Either way you are going to need two or four "heads" that are mounted in the airdamn, that cannot be hidden behind the grill...
Worse, the fuzz in my state has been hiding on overpasses/bridges to increase their odds of not being seen...Now that they're above you aiming their laser guns at a downward angle, this greatly reduces the effectiveness of the laser jammers...
Just be aware that the Valentine is highly detectable so in states like Virginia they WILL get you pulled over for illegal use.
Bell claims that there's is truly stealth at this point in time? I dunno.
I know Valentine ain't cause I got nailed over Thanksgiving. Well, technically my wife got nailed.
"Q: Does it find the V1? A: Very likely, according to reports we've been hearing from a few V1 users."
Trapster on my droid phone? will check it out right away. Can you give your personal thoughts on how it works? thanks.
Valentine was my detector of choice since '86.
There are lots of car forums advising on stealth mounting with a google search but nothing specific to Jaguar that I could find.....perhaps you can get some ideas from them however.
Unless your reaction time is faster than the speed of light laser detectors just let you know to smile for the photo or the officer.
Their projection band is so narrow there is no doubt that they have the right car.
It is like a pencil beam vs the shot gun scatter and emissions of radar that can give you miles of detection in open country and lots of other targets in urban settings.
Assume trapster is an app updating local speed traps, yes?
I still have my V1 but since it is on the wrong bands for Euro radar and they are so illegal that they have the choice of destroying the detector on the spot or confiscating your car, and useless for laser as I say, there is not much point over here.
It is so bad in Switzerland that it is also illegal for Sat Nav systems to indicate where fixed radar/laser cameras are. No Sat Nav company is permitted to program their GPS systems for them in Switz.
And they have plenty....one friend got ten tickets in 20 minutes between Geneva and Luasanne, 1,000 bucks! With a 100 cameras in Geneva they generate over $300 Million in tickets a year.
Did I mention that the tolerance for over the limit is 1.5km on laser cameras here?
The speed limit on the Autoroute is 120kph...which is to say you have to be within less than 1% of the speed limit to avoid a ticket.
And oh yeah....ticket fines are based on your income or assets for over 30kph or 18mph above any speed limit.
DC and Virgina don't sound so bad now do they?
Laser jammers....hmmm might be worth a shot....but does anyone have hard data that they work besides the guys selling them?
cheers,
jj
cheers,
jj
cheers,
jj
cheers,
jj
So has Switzerland change that much?
It sounds terribly restrictive. Maybe you should leave ...
The nice thing is there in the US, many states do not outlaw the use of a laser jammer (lasers are not governed by the same body that governs radar) so laser can be defeated. There are lots of sites that compare the jammers out there and say they work. Since they are active jammers, they send back a stronger signal that is incorrect.
I spent the last 4 days in NY state and they were using radar universally but how they were using it was interesting. Some were using instant-on but the bleed through of the usage was easily detectable in the more crowded locations.
The majority were just leaving the damn thing on all the time, state and local officers. I guess they are still going after the fat part of the revenue curve which is mostly people with no detectors in their cars.
I haven't been using my V1 for quite a few years so I upgraded it via their trade in policy and I don't know if it's a change in the unit or what but this thing now goes off on just about every signal there is anywhere. I used to utilize the the smaller "L" setting on my older unit and that stopped the spurious warnings but this version just won't shut stfu. It's very different.
Even in the illegal states, need to check specific laws because they just may be slap on the wrist fines...
With all laser guns, jammers can only "jam" a certain distance...Jammers are weakest to the traffipatrol line of laser guns...
Well if I was serious I would mount it using the rear view mirror. It looks a LOT cheaper to do now!!
Radar-Mirror
Radar-Mirror
New Jersey Laser Jammer Laws - Guys of LIDAR
So I had a look and ... there's that GD Virginia again!
They must have a bug up their collective a**.
USA Laser Jammer Laws - Guys of LIDAR
But based upon what I see I predict it will become a completely red map in the not too distant future.
The major problem is counties using speed traps to prop up their overspent budgets - I say boycott all your purchases in those counties and make it well known why. I stopped a business locating a factory into Putnam because of the **** county...
Good choice on the V1...
love the machine.. great help when reveling to unknown location...
if you have money to spend.. you can have the V1 integrated to the rear view mirrors....
Custom Valentine one radar in rearview mirror - YouTube
good luck...and happy new year..
