Key and Fob Purchase and Programming
Old Nov 26, 2012 | 07:07 PM
  #41
McJaguar's Avatar
Originally Posted by Six Rotors
I JUST NOTICED---if you changed the battery and the Fob did not work there is a good chance that the Fob is NFG.
so... if I'm understanding this correctly, I shouldn't have to reprogram a FOB after replacing the battery? So if I replaced the battery because the FOB stopped working, and it still doesn't work, it's not a programming issue, but the FOB is no good?
Do I understand this correctly?
Old Nov 26, 2012 | 08:07 PM
  #42
Six Rotors's Avatar
Yes that is the most likely case.
When the battery begins to run down,the remote loses its range and becomes slowly less effective.
If you remove the battery you will not have to reprogram the remote.Replace the battery and the remote will work.
If your remote works fine one day and suddenly stops the next day it is not usually the battery.If you replace the battery and it does not work,the remote is most likely defective.
Old Nov 27, 2012 | 01:26 AM
  #43
catstyle's Avatar
I've seen at least a couple of FOB related bulletins at https://www.jaguarforums.com/forum/s...lletins-10586/
One of them says "It is possible that following a vehicle being parked for a length of time, overnight for example, that the
vehicle will not respond to the remote transmitter." - could it be your case?
Another recommends dealers to insert an isolating padding inbetween buttons and the circuit board b/c of static that can potentially kill the fob, I've opened mine and it was there - I'm lucky.
Old Nov 27, 2012 | 05:03 AM
  #44
JagV8's Avatar
I replaced my fob battery and did not need to reprogram. Do check the button contacts are OK inside and that no shorting out can occur (thus the pad).
Old Nov 27, 2012 | 11:18 PM
  #45
catstyle's Avatar
Another thing that took me some time to figure out was that the battery needed to be inserted "upside down", - looks up and + down
Old Dec 20, 2012 | 02:35 PM
  #46
1320racer's Avatar
Default Brand New Remote w/ Uncut Flip Keys (2 @ $164.95)
ebay: BRAND NEW - UNCUT KEYS w/ REMOTE - GUARANTEED TO WORK
I just purchased two keys for $164.95 (FREE shipping) and will provide an update on how things turn out. I'm still searching for the best "current" deal to have the keys cut and programmed.
I went the ebay route since local dealers in Maryland and Northern Virginia are currently quoting $320-$366 for each key and $130 to program the keys. I have no problem paying dealers a bit more but the difference is just too big for keys. Last evening on ebay I saw USED remote key fobs for ~$10-$50 which would require blank keys that sell for ~$5-$30.
This part is compatible with 23 vehicle(s).
Notes Year Make Model Trim Engine
2008 Jaguar S-Type All All
2008 Jaguar X-Type All All
2008 Jaguar XJ8 All All
2007 Jaguar S-Type All All
2007 Jaguar X-Type All All
2007 Jaguar XJ8 All All
2006 Jaguar S-Type All All
2006 Jaguar X-Type All All
2006 Jaguar XJ8 All All
2005 Jaguar S-Type All All
2005 Jaguar X-Type All All
2005 Jaguar XJ8 All All
2004 Jaguar S-Type All All
2004 Jaguar X-Type All All
2004 Jaguar XJ8 All All
2003 Jaguar S-Type All All
2003 Jaguar X-Type All All
2003 Jaguar XJ8 All All
2002 Jaguar S-Type All All
2002 Jaguar X-Type All All
Old Aug 26, 2013 | 06:21 PM
  #47
duncan12's Avatar
Default UK key supplier for 2004 X Type circuit board repair
Has anyone in the UK had good dealings with suppliers who fix faulty key fob's. My X Type key (I only have one) had the battery replaced but it still only works intermittently so I assume it is the circuit board needing replaced/fixed.
Appreciate any help if you know of a quick and reasonably priced locksmith who does a fast postal service.
Old Aug 27, 2013 | 01:08 AM
  #48
JagV8's Avatar
I think someone on the UK forum posted about it and that they'd sent fob(s) away to a guy on ebay with good results.
Old Aug 27, 2013 | 12:47 PM
  #49
capt's Avatar
I was very surprised to find that the Jaguar dealer in West Palm Beach, FL. only charged $10 each to cut the key blanks I provided. The parts man did them while I waited. He was the only one I could find that had the special cutter required.
Old Aug 30, 2013 | 06:31 PM
  #50
Richard Moss's Avatar
I see that Partsgeek are selling Lincoln LS fobs that look a LOT like the S-Type one. Does anyone know if they are suitable for our cars? Mine is a 2001 (pre-facelift) car.
00 2000 Lincoln LS Key Fob - Body Electrical - Dorman - PartsGeek
Old Oct 17, 2013 | 12:38 AM
  #51
dchamero's Avatar
Default Dallas area?
Does anyone know of a locksmith in the Dallas, TX area that can program a 2003 S type?
Old Oct 17, 2013 | 01:45 AM
  #52
JagV8's Avatar
Chances are a local jag dealer is your only option. Where's Brutal...
Old Oct 17, 2013 | 02:09 AM
  #53
dchamero's Avatar
That sucks... when I bought my car, the previous owner had lost one key so he only had one keyfob, and I don't feel at ease having only one key for the car, but the dealers want a ridiculous price for programming a key....
Old Oct 17, 2013 | 03:43 AM
  #54
JagV8's Avatar
It's a hard car to steal. Some things just cost.
Old Oct 17, 2013 | 08:29 AM
  #55
Just imagine the cost when you lose it.
Old Oct 17, 2013 | 11:10 AM
  #56
dchamero's Avatar
I just got a quote from a local locksmith for $280 for a transponder key (just a simple key, no fob)... but that is not that much different than the dealership....
Old Oct 17, 2013 | 11:19 AM
  #57
I just bought 1 new key supplied and cut by the dealer and had two new fobs (sourced elsewhere) and both keys and fobs programmed total $213.31 inc tax.
Old Oct 17, 2013 | 11:22 AM
  #58
dchamero's Avatar
Wow, where?
Old Oct 17, 2013 | 11:43 AM
  #59
Phoenix, not reputed as the cheapest of dealers.
Have you tried all the local dealers, we have a member with a shop in Decatur who might be able to help you.
Old Oct 17, 2013 | 12:08 PM
  #60
dchamero's Avatar
Yes, you are right, I'll have to check all the local dealers in person (I tried by phone or by email but it looks like you have to go there in person to get a price...)
