Key and Fob Purchase and Programming
Old Oct 21, 2013 | 03:58 PM
  #61
phaelax's Avatar
My fob hasn't been working lately. I thought maybe the battery, but it's only the unlock button that doesn't work all the time. If I did replace the battery, it wouldn't need reprogrammed would it?
Old Oct 21, 2013 | 04:09 PM
  #62
No, a battery change is straightforward, give it a good clean and check the switch connections when you have it apart.
Old Oct 21, 2013 | 09:52 PM
  #63
phaelax's Avatar
I took it apart, battery is fine. But there's some corrosion over the buttons, and the unlock button in particular has a honey-like goo on it and the connection seems loose. I might just buy a new fob on ebay just to be on the safe side. I don't have the valet key or anything for the doors. So if this goes out, I'm locked out.
Old Oct 22, 2013 | 01:03 PM
  #64
tbird6's Avatar
You can change the membrane switches too. I did not know this until it was posted on the forum. Very inexpensive and they are on EBay.
We had a good informative thread on it too.
Old Oct 22, 2013 | 09:35 PM
  #65
stypecat's Avatar
You know the name of the shop in Decatur?
Old Oct 23, 2013 | 08:04 AM
  #66
aholbro1's Avatar
Sounds like they are talking about Motorcarman. He has WDS and can program FOB's and do all the dealer-set-up tricks like turn drive-away-locking on or off as you like.
Old Oct 23, 2013 | 08:38 AM
  #67
sprdav33's Avatar
Spraying the switches on the circuit board real good with electronic contact cleaner might be enough to fix your problem.
Old Oct 23, 2013 | 04:46 PM
  #68
phaelax's Avatar
I went ahead and ordered one on ebay for $35. I tried cleaning the circuit, but the button feels mushy and I have to push real hard to get it to work. A local locksmith said they can program it for $60. I'll have to call the dealership to confirm, but I believe they told me they only charged $45 for the programming.
Old Oct 23, 2013 | 10:04 PM
  #69
sprdav33's Avatar
You can also order the buttons on eBay if you want to try to replace them.
Old Mar 2, 2015 | 05:53 AM
  #70
slipup's Avatar
Thanks for the info on Central Lock & Key. I was in the process of trying to locate a smith that can do this and you just saved me a lot of time!
Old Oct 22, 2020 | 12:09 PM
  #71
Trisha Kenney's Avatar
Default Please help!!!!
WHERE did you get this done pls help!! I had the same EXACT experience and Im having a nightmare trying to find somewhere or someone who can do this programming before mid-november. if anyone can offer any names or information on anyone offering the services in the state of Washington I'd be eternally grateful. Thank you
QUOTE=YoungRobertL;591487]Had quite the experience replacing a key that was stolen from my 1998 XJ8. Finally bought the cut key from the Jag dealer in Tacoma, WA. Then had to have my car towed to a local shop that works on Jags (there is no Jag dealer in Yakima, WA). The shop programmed my key and remote & both work just fine. $135 for key & cutting, $130 for programming.[/QUOTE]
philwarner
Oct 4, 2024 01:37 PM
XJsc-guy
Nov 23, 2015 01:56 PM
jfitzoz
Sep 7, 2015 04:28 AM
Rick Michael
Sep 6, 2015 06:53 PM
My Pham
Sep 4, 2015 03:37 PM
