Key Fob Quit Working
Old Feb 23, 2017 | 06:41 PM
Cobbler's Avatar
Default Key Fob Quit Working
Hey Gang, My fob quit working. The battery is fine in both the car and the fob. I went to check to make sure I locked the car and nothing happened. I pulled the fob battery and checked it for strength and it's fine, the car battery is fine. Any ideas? Just plain ole quit working....
Old Feb 23, 2017 | 07:53 PM
JBzXJ40's Avatar
Do the buttons feel like they are " clicking "? If so, then it may be the key fob has lost programming, or it has died. Is there any green stuff on the little circuit board inside the remote?
Old Feb 23, 2017 | 08:06 PM
aholbro1's Avatar
Happens from time-to-time. Take your second one and use it for a day or two, then try the dead one again. Can't explain why, but has worked on both of mine in former times.
Old Feb 23, 2017 | 08:16 PM
motorcarman's Avatar
Info here
File Type: pdf
File Type: pdf
Old Feb 24, 2017 | 04:32 PM
Cobbler's Avatar
Thanks Guys! I saw somewhere that the flapper in the ignition switch will cause it to not work so I worked the key in and out several time and the fob works now. I'll put a small amount of lube on the flapper and maybe that will keep it going for a while....thanks again.
Old Feb 24, 2017 | 04:34 PM
Cobbler's Avatar
No, it was nice and clean...
