Knock sensor location
Old Nov 20, 2016 | 12:41 PM
marcoxpolo's Avatar
Default Knock sensor location
I have an 2003 S-Type R, the knock sensor is malfunctioning. Need some guidance on location, thanks
Old Nov 20, 2016 | 01:40 PM
Welcome to the forum marcoxpolo,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Nov 20, 2016 | 01:58 PM
JagV8's Avatar
Which code(s)? (It's not THE knock sensor...)
BTW the workshop manual is a free download though you may need more posts.
Old Nov 23, 2016 | 02:53 PM
Ducmon's Avatar
Check the battery first and then the connections.
I had this problem and found it to be the battery and a corroded connection.
This video that Norrie found is for my engine but it may help.
It is around 9 mins 20 secs. Showing the position of the connector
Old Dec 1, 2016 | 01:20 PM
jazzyjags's Avatar
Both bank 1 and 2 knock sensors are located under the supercharger on the "V" or valley part of the block. I believe that they are impossible to get to without removing the supercharger. If you find a way to access them without taking out the supercharger let me know. I'll be changing mine within the next week too. I've removed the supercharger in the past, its a real pain in the neck to do.
CyJag
38
Apr 23, 2017 10:58 PM
97XJR-Flausa
Nov 7, 2016 08:52 PM
geoff le friec
Oct 25, 2016 03:31 AM
carelm
Oct 22, 2016 07:37 PM
