leaking from cap
Old May 2, 2012 | 09:47 PM
slideshow801's Avatar
Default leaking from cap
so jaguar s type 4.0 had started to overheat i changed the thermostat still same. i now noticed major leaking from under the car where reservoir.
from what ive read seems they crack and what not, well from what i have seen on mine it seems to be leaking from under the cap what would cause that? would it simply be just faulty tank?
car takes 14 mintues for temp needle to even want to start to rise. after the like 15 mins the needle gets to half way point and stays there for like 2-3 mins then i smell coolant and fans start to turn on and it starts to leak then temp starts to rise
any ideas?
Old May 2, 2012 | 10:49 PM
QuartzSTypeR's Avatar
The seal on the cap could be bad. Make sure the cap is on tight. If it is, replace the cap; if the leak stops, great. If not, replace the tank.
Old May 3, 2012 | 10:49 AM
abonano's Avatar
+1 QuartzSTypeR - Check the Cap/Gasket, and Overall Condition of the Tank - also check all the hoses and connectors associated with the tank. Good Luck.
kelliott
May 31, 2022 05:26 PM
abonano
25
Sep 25, 2015 10:43 AM
Papelione
Sep 21, 2015 06:13 PM
jagent
Sep 12, 2015 09:10 AM
Xkr x100
Sep 6, 2015 08:50 AM
