Leaking power steering fluid
Old Oct 10, 2008 | 08:45 PM
ccajun4real's Avatar
Default Leaking power steering fluid
I recently noticed noise when I turned the steering wheel and in general especially when starting the car up. I checked the PS fluid and found it to be very low.
I added about 1/2 quart but now the fluid is leaking out on my garage floor little by little each day. I have not put the car on the lift yet to see exactly where it is coming from. The noise is gone so I dont think it is the pump. Is there a common issue that causes a leak in R & P of the S type?
I have a 2000 4.0 with 130k miles. Thanks in advance.
Cajun
Old Oct 14, 2008 | 08:07 PM
Default RE: Leaking power steering fluid
Anyone have any idea where I should look for the leak? I want to diagnose before I take it to a shop and let them charge me $100 just to take a look and tell me it will cost $500 to fix. Thanks guys
Old Oct 14, 2008 | 08:08 PM
ttt...........
Old Oct 14, 2008 | 10:03 PM
racerx82's Avatar
Well....it could be: Pump seal, cracked hose (high side or low side) and or the rack has a leaking seal.
So without seeing it, were difficult to pinpoint.
The fix might be as simple as tightening the hose ends, or complicated as in replacing the rack and having to get an alignment. Or worse yet, the shady mechanic charging you for the hose, pump and rack when you only need an O-ring between the hose connection......
sorry
and good luck
aholbro1
Dec 29, 2024 06:46 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
