Limited Slip from the F Type??
Old Sep 11, 2013 | 04:45 PM
tbird6's Avatar
Default Limited Slip from the F Type??
We all know that getting a limited slip rear end into an S Type is not easy or cheap or if it's even possible in the STR.
But the new F type has two levels of limited slip rear ends depending on what model of the F Type you buy.
Does anyone know if the F type uses the same rear end as the S Type?
The E-diff would be tough to use even if it bolts in because it requires the stability control system to operate it. But I found on the lower level F Type they have a limited slip rear listed instead of the E-diff.
Anyone know what the difference between the two are? Sounds like the limited slip is not electronically controlled?
and the bad boy F type S V8.
Attached Thumbnails Limited Slip from the F Type??-f-type-s.jpg   Limited Slip from the F Type??-f-type-s-v8.jpg
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
XFR_Gold
Sep 2, 2015 12:24 PM
