Loss of power and poor performance (2.5)
Old Aug 1, 2013 | 04:22 AM
0x61's Avatar
Default Loss of power and poor performance (2.5)
Hey guys,
I'm having some serious trouble with my car. I can't get over 160km/h. The car is revving up untill maximum though. What I do notice is that, when you get let's say 120km/h and you're giving full gas the car doesn't increase in speed for a second then it does speed up and then again it's stops for a second and speeds up later. It seems like it's leaking air somewhere.
The car has LPG on it, however both on gas or gasoline it remains the same.
I don't have the 'Limited engine performance' notification and it did a OBD scan myself. Here are the results:
Code:
P0191: Fuel rail pressure sensor circuit range/performance
P0430: Catalyst system efficiency below threshold
P1549: Variable induction system 1 low/high input/intake manifold communication control A circuit malfunction
It would be amazing if you guys could clear something up as I don't really understand what these codes exactly tell me.
Thanks in advance
Old Aug 1, 2013 | 08:59 AM
JagV8's Avatar
Clear them and see if they come back. Does your OBD tool have "live data"? If so, look at LTFTs (see my sig) warmed up at idle & about 2500rpm (in P or N).
When you have more posts you can grab the free JTIS and codes PDF. They have details of the codes and the known causes.
Old Aug 5, 2013 | 08:48 AM
0x61's Avatar
Hey JagV8 thanks for the response. However it seems like one of the cat's were bad. Cleaned it up, and everything is ok now
Old Aug 5, 2013 | 09:00 AM
police666's Avatar
What did you do to "clean the cat"
Wolfy
May 28, 2024 08:06 AM
oyster
Sep 12, 2015 01:01 PM
Wolfy
Sep 11, 2015 06:27 AM
mrplow58
Sep 9, 2015 11:27 AM
XFR_Gold
Sep 2, 2015 12:24 PM
