Low fuel pump pressure (p1235)
Old Nov 29, 2016 | 04:10 PM
alexx93's Avatar
Default Low fuel pump pressure (p1235)
Hello!
Jaguar S-type, 2004 YOM. 4.2L
I have troubles speeding up, engine chokes. Trouble code p1235 showing up on diagnostics (Fuel Pump Control out Of Range (Fuel Pump Driver Module/VLCM)).
I have checked the following things:
-fuel pressure at rail is 30psi, no fuel leak anywhere.
-control signal coming to fuel pump is about 6-7V (Simple Voltmeter in DC mode, will take a look at oscillosope tomorrow), so yet Duty cycle of PWM seems to be about 50%
-pump can give up to 87psi pressure on the testbench. Pump is fine.
-filter is not clogged. fuel is good.
Looking for some advise, what to check else.
Tomorow I will continue diagnostics.
Best regards,
Alexander
Old Nov 29, 2016 | 07:39 PM
abonano's Avatar
Originally Posted by alexx93
Hello!
Best regards,
Alexander
Hi Alex,
Fuel pressure is low. Signal to the fuel pump should be at least 10.5V or higher (I believe)
Had the fuel filter been changed? You say it's good but when was it changed last and if recently, was it installed in the right direction?
That's my $0.02 for now.
Old Dec 1, 2016 | 06:51 AM
alexx93's Avatar
Originally Posted by abonano
Hi Alex,
Hello,
Thank you for response! I have checked filter earlier and it seemed to be clean, but now I have changed it and the problem is solved!
Thank you very much!
Old Dec 1, 2016 | 07:08 AM
joycesjag's Avatar
Default No
I have checked filter earlier and it seemed to be clean, but now I have changed it, problem solved.
How exactly does one go about checking a fuel filter that is encased entirely by steel?
Old Dec 1, 2016 | 07:27 AM
JagV8's Avatar
Unless it's cut open I think it's an inexact process!
Old Dec 1, 2016 | 09:35 AM
alexx93's Avatar
Yes, I see. Even once I took it out, I cut it and it seemed to be cool. It was just unexpected for me that it was real reason.
Old Jul 22, 2023 | 04:23 AM
avanti357's Avatar
wrong thread
St. Stephen
May 4, 2021 05:53 PM
studeb
Mar 31, 2020 03:10 PM
gameover
Jun 12, 2018 04:32 PM
John Baker
Dec 29, 2017 05:05 AM
t.nellessen27
Aug 4, 2014 09:50 PM
