Lowering springs, camber, and uneven tire wear
Old Jul 24, 2013 | 03:06 PM
Under Pressure's Avatar
Default Lowering springs, camber, and uneven tire wear
As many of you know my car is lowered on H&R lowering springs. Before I bought and installed them, I had asked if other people on lowering springs on this forum had issues of uneven tire wear due to camber but the responses I got was no. After lowering my car, I got alignment done the best the shop could do (to Brutal's specs) but the camber bolts only went so far. I was left with slight camber that unlike my several prior lowered Mercedes, you could not tell by looking at the car. It seemed okay. By comparison, my lowered Mercedes' in the past had such nasty camber that you couldn't align out that the wheels looked bowed out in the bottom.
Well, I am getting slight uneven tire wear on the inside edge of the tires. I do not know if I am asking for advice, or just putting it out there for someone to find doing a search prior to lowering their STR but my camber has left me needing new rear tires after about a year of driving it lowered. Fyi I guess.
Old Jul 24, 2013 | 04:57 PM
Michael Star's Avatar
Really? Mine has been lowered for 2+ years with no noticeable wear on the inside edge. I've had 3 sets of tires. I believe i have somewhere around 1.5 degree of neg camber.
How much less is it than the outside?
Old Jul 24, 2013 | 07:46 PM
GT42R's Avatar
alignment can get knocked out quite in easily in these cars, it's honestly a good investment to align at least twice a year on an STR...
inside tire wear is insanely common on STR's, and it's always due to toe.
in fact, on any car, severe inside tire wear is almost always due to toe;
in other words, it's likely not your camber, but your toe being out, check for any play in the suspension when you have it up on the alignment rack,
my STR had a tire wear issue, toe was way out, now i keep on top if it, and tires are wearing very evenly,
bigger wheels, less sidewall, more likely to bump the alignment off in an STR...
Old Jul 24, 2013 | 09:20 PM
Bad Cattitude's Avatar
Have you considered slotting the holes for the camber bolts?
Old Jul 25, 2013 | 05:21 PM
plums's Avatar
Of the three angles, toe is the easiest to check yourself. Remember what Brutal says about pushing out the tires before measuring to mimic the effect of the road when in motion.
ym37tech
Feb 8, 2016 01:04 PM
08Z06
Oct 24, 2015 05:46 PM
1LowCat
Sep 14, 2015 07:51 PM
1964Daimler
Sep 9, 2015 11:28 AM
AirCommando
Sep 8, 2015 07:19 PM
