Lug nut
Old Feb 2, 2014 | 01:54 PM
jaguarx00's Avatar
Default Lug nut
Apparently my car has cheap lug nuts and this one is stuck/broken meaning it won't come off.
Tried a few different tire shops and none can take it off and some jacka** made it worst by the pics
:[ only solution I heard is to use a torch but I don't want to mess up my rim more than it is already. How do I get this sucker off?!
Old Feb 2, 2014 | 02:10 PM
abonano's Avatar
Ouch!
Your best bet is to drill around the stud - but I'm sure there are other ideas out there... Or the stud itself will need to be cut/drilled out.
Be sure to get 1 piece lug nuts...
Old Feb 2, 2014 | 02:18 PM
jaguarx00's Avatar
Originally Posted by abonano
Ouch! Your best bet is to drill around the stud - but I'm sure there are other ideas out there... Or the stud itself will need to be cut/drilled out. Be sure to get 1 piece lug nuts...
Yeah heard maybe with a metal drill . I'm sure I'll have to change out the stud as we'll. this sucks. Those are original lug nuts
Old Feb 2, 2014 | 05:37 PM
phaelax's Avatar
Ran into the same issue few years ago. If you do drill it out, make sure you have the proper drill bit for it. I used my regular bits for drilling through metal and I couldn't get through the stud with it.
If you search the forum, there's a few threads about different lugnut options.
Old Feb 2, 2014 | 08:26 PM
Injekter's Avatar
drill it out... titanium cobalt bit if you can get them, if not then cobalt..
Old Feb 2, 2014 | 09:50 PM
kr98664's Avatar
Good info for you in this thread:
https://www.jaguarforums.com/forum/s...en-lug-107177/
Old Feb 2, 2014 | 10:14 PM
jaguarx00's Avatar
Thanks guys^
Poet
Feb 7, 2025 02:18 PM
max224
Jun 21, 2024 12:17 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
