lug nuts
Old Dec 31, 2008 | 11:31 AM
kiloslanga's Avatar
Default lug nuts
Seemssome ofmy nuts are strippped and need to be changed. Does u guysknow if i can use any lug thats 12x1.5 ?
Old Dec 31, 2008 | 11:36 AM
justinb67's Avatar
Default RE: lug nuts
As long as the thread is the same you are fine,but you need to make sure that the lug matches the wheel. The original lugs on my 03 s-type had a flat washer face on them. My new wheels are splined with a standard taper, so it depends on the wheel. You cannot mix and match flat faced and tapered lugs (and some lugs have different taper, but mostly for race cars, they use 45 deg taper vs 30 deg if memory serves me well)
If you can't find the proper lugs at a parts store, then a local tire shop will definitely be able to get you the right lugs. I know the washer faced lugs that were original on my car aren't sold in the autoparts stores in this area.
Justin
Old Dec 31, 2008 | 11:43 AM
kiloslanga's Avatar
thanks. that was quick.
Old Dec 31, 2008 | 11:49 AM
justinb67's Avatar
no problem. Just happened to be on, posting.
Poet
Feb 7, 2025 02:18 PM
max224
Jun 21, 2024 12:17 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
