MGP Caliper Covers
Old Oct 26, 2021 | 04:30 PM
max224's Avatar
Default MGP Caliper Covers
I searched previous caliper cover threads but didn't find anyone with this exact problem. Ignoring the aesthetic debate, I have a set of MGP caliper covers on my 2000 XK8 and recently purchased a set for my 2002 S-Type (non "R"). When I went to install them I found that they interfered with the wheels and removed them. Has anyone else run into this problem? I've contacted MGP but they don't seem that interested in helping me and won't allow me to return them. Any thoughts, or should I just take the $$$ loss and chalk It up to experience? I guess I could consider wheel spacers, but that's a can of worms I have no interest in opening.
Old Oct 26, 2021 | 08:14 PM
xalty's Avatar
my suggestion is pay up and get the STR XF XK 355 calipers
Old Oct 26, 2021 | 09:10 PM
max224's Avatar
A good suggestion only I've already installed new rotors and pads so that would be more money out the window. Probably would have had to buy new calipers to go with the larger rotor. Unfortunately, it also wouldn't help with th original issue of fitting new caliper covers.
Old Oct 28, 2021 | 01:05 PM
max224's Avatar
Not wishing to prolong the misery, but upon further investigation, NO caliper cover will fit since there is almost no clearance between the back of the wheel and the face of the caliper. I'm wondering if the previous owner switched out the factory wheels for aftermarket ones even though these look stock. If someone could quick-check their car and give me a guesstimate of that gap it would greatly appreciated. In any case, I'm probably going to have sell the covers since I'm go and change out the wheels (if thery're the problem.
Thanks.
Old Oct 28, 2021 | 04:09 PM
cats4.2's Avatar
I measured 7mm on the rear. Mine is a 2003 with 17 inch "Kronos" wheels. Will get it more accurately later.
Old Oct 29, 2021 | 07:37 AM
max224's Avatar
Thanks, but not necessary. That measurement is the order of magnitude I was looking for. It will definitely help to keep me from driving myself crazy on this issue!
Old Oct 31, 2021 | 04:29 PM
max224's Avatar
The gaps between the wheel and the caliper face are almost non -existent on front brakes and about 1/4" on the rears. I had replaced the disks and pads (which seem to be working well) and wonder if I could have somehow mixed up the rotor placement, although I'm sure the front and rear rotors are different diameters. Other than that, could I have received the wrong rotors somehow? I'll do some on the car measurements and find out.
Any suggestions greatly appreciated.
Old Oct 31, 2021 | 04:45 PM
xalty's Avatar
the regular s-type is 300mm front 288 rear
03-05 sport package is 320 front 288 rear
the sport caliper bracket is marked X350, which is where it comes from. it may have been swapped over
Old Oct 31, 2021 | 08:38 PM
max224's Avatar
This is a 2002 with the Sport package and the 4.0L V8.. Can I assumeit was fitted with the 200mm front rotor or the 320mm one? Also, would the diameter of the rotor have anything to do with the clearance between the wheel hub and the caliper face? I still have the old rotors and am going to measure them against the replacements. I'm also wondering if I could have gotten the front and rear rotors mixed up somehow, even thought they labelded front/rear and left/right. This may very well be a self-induced problem (definitely not my first one and probably not my last)!
Old Nov 1, 2021 | 06:14 PM
NBCat's Avatar
Originally Posted by max224
This is a 2002 with the Sport package and the 4.0L V8...
@max224, please post a picture of the front wheel mounted on the vehicle.
Old Nov 1, 2021 | 08:19 PM
max224's Avatar
'll send it out tomorrow morning. Supposedly there are different front rotors for the standard and Sport (computer-controlled) suspensions. I have the latter. I'm wondering if I was supplied with the rotors for the standard suspension.
Old Nov 2, 2021 | 02:45 PM
max224's Avatar
Attached is a photo of the mounted wheel and one showing how tight the gap is between the wheel spoke and the caliper face. Below is fitment information from Detroit Axle which shows that the standard front rotor is incompatible with a Sport suspension vehicle.
Fitment:
  • 2000-2006 Lincoln LS
  • 2000-2002 Jaguar S-Type
  • 2003-2005 Jaguar S-Type Models with Standard Suspension ONLY Rotors are 300mm (11.8″) in Diameter (Will not work with Sport Suspension)
  • 2002-2005 Ford Thunderbird
philhef
Jun 1, 2022 08:36 AM
Sportjag
Sep 24, 2020 04:49 PM
Dubzeey Wu
Aug 9, 2019 11:08 AM
ralphwg
Dec 1, 2016 05:09 PM
NSY
Oct 15, 2016 11:20 AM
