Misfire
Old Feb 4, 2015 | 10:56 PM
Mooch1983's Avatar
Default Misfire
Misfire on #5
I just replaced all 6 coils and all 6 spark plugs, upper gaskets and I still have a misfire.
I'm going to scan tmrw to see if any of the codes changed but I don't think they have.
What else could it be?
Old Feb 5, 2015 | 12:19 AM
QuartzSTypeR's Avatar
Did you use OEM plugs and coils? Could have a defective coil, bad connection, fuel injector, low compression/bad valve, etc...
Old Feb 5, 2015 | 01:03 AM
JagV8's Avatar
Car info? Year, engine (suppose 3.0) etc?
Old Feb 8, 2015 | 11:56 PM
Warspite's Avatar
X2. Using an Accel coil rated for different output, or use of certain aftermarket plugs will have you chasing ghosts.
Old Feb 9, 2015 | 10:13 AM
Jon89's Avatar
If you have the 3.0 V6 and have not replaced your two factory Intake Manifold Tuner Valve O-rings (IMT O-rings for short), that could be your culprit. The factory IMT O-rings (yellow in color) were poorly designed and tend to start leaking as the years go by, usually throwing misfire codes. The improved IMT O-rings (green in color) are much thicker and sturdier and usually solve the misfire problem....
I replaced mine in January 2010. Zero misfires since. The part number is C2S40669. You'll need two. Be sure the new ones are indeed green....
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
