Need help with S Type Chugging
Old 02-16-2016, 02:14 PM
edankeven's Avatar
Default Need help with S Type Chugging
Just replaced upper valve cover gaskets, intake manifold gaskets and 6 spark plugs. It stopped oil leak and seemed to go well. Before putting intake manifold back on I sprayed seafoam inside and than rinsed out with water after letting it sit for awhile. After letting it dry or at least seemed dry I put it back on and started car. It idles fairly gentle, better than before work but is chugging off and on when I drive, during acceleration or even revving while idle. Did I possibly not let manifold dry all the way? Seafoam a bad idea? Could I have installed spark plugs wrong? or to tight? THank you for any help!
Old 02-16-2016, 02:48 PM
JagV8's Avatar
Received 4,489 Likes on 3,906 Posts
Maybe the hose under all that lot has perished, as they do with age.
Old 02-16-2016, 04:59 PM
edankeven's Avatar
it would be just my luck that would happen after I put it all back together.
Would that make engine shake and run like crap?
Old 02-16-2016, 06:02 PM
joycesjag's Avatar
Received 1,695 Likes on 1,210 Posts
Why yes, yes it will edan..
Look in the first paragraph in the following link for Gus's link to his Jag repair page.
https://www.jaguarforums.com/forum/s...ics-faq-52720/
edankeven (02-17-2016)
rickpwilson
08-20-2020 10:08 AM
Murphy.96
02-12-2016 12:27 PM
car5car
02-10-2016 07:41 PM
viper1996
02-10-2016 09:16 AM
superA
01-30-2016 09:30 PM
Quick Reply: Need help with S Type Chugging
