Need some advice on brakes!
Old Nov 13, 2009 | 06:49 PM
reddrawf's Avatar
Question Need some advice on brakes!
Time is near to put on new brakes. I'm in a quandry over what to buy. Do I go with standard OEM parts or something else? I'm thinking of dimpled, slotted rotors for the looks. I really don't think I need more performance as the OEM ones served me well.
Here are some options:
OEM Rotors and pads = $578
EBC = $519
Rotors 3g dimpled and slotted
EBC Redstuff pads
Brake Performance = $458
Premium dimpled & slotted, silver rotors
Ceramic pads
Other options? Is Brake Performance good? Any suggestions advice is greatly appreciated.
Old Nov 13, 2009 | 09:51 PM
joycesjag's Avatar
Whatever you decide on the rotors, I would definetly go with ceramic pads for the brake dust issues. Unless of course you do not mind dirty wheels.
Old Nov 14, 2009 | 01:03 PM
JOsworth's Avatar
I would go with the Brake Performance package. I personally used Centric's performance semi pads and have very little dust despite my S being used as the daily commuter. I'm not a big fan of ceramics. Then again, I am a "very enthusiastic" driver. Ceramics should be fine for your use.
As far as the vendor goes, I'm not sure. Post a link to what your looking at. I'm sure if anyone has had experience with them, they will chime in.
Old Nov 14, 2009 | 03:23 PM
reddrawf's Avatar
The Brake Performance website is: http://brakeperformance.com/site/index.php
Old Nov 14, 2009 | 10:44 PM
Mikey's Avatar
Why do you want/need new rotors?
Old Nov 15, 2009 | 08:10 AM
Jon89's Avatar
I put a set of Wagner ThermoQuiet semi-metallic pads on our S-Type's front axle back in July. Got them at Advance Auto Parts for less than $60. Our front rotors were fine so I didn't turn them. The brakes are now dead-silent and the car stops on a dime. Brake dust is about a quarter of what it was with the OEM pads....
I rotated the tires last Sunday after doing an oil & filter change. Took a close look at the brake components on all four corners. Front pads still look new as expected. The surprise was how good the factory rear pads still look. Many S-Type owners report wearing out their rear pads first. Ours appear to have about 50% of the pad surface left at just over 36,000 miles on the car. My wife does a lot of highway driving which is probably a big contributing factor for that....
Old Nov 15, 2009 | 09:17 AM
tbird6's Avatar
Jon89 you have the V-6 so I would not expect as much rear brake wear. If you have a V-8 or STR the high torque of the engine causes the traction control to kick in much more than you think. You won't even notice but any bit of wetness on the road will trigger it for just a split second.
Old Nov 15, 2009 | 01:42 PM
reddrawf's Avatar
Done a bit more research and here are some options I've come up with. Undoubtedly tere are many more options out there. Note, all US vendors and USD currency
Rotors for 300mm + pads
Base Line is Jaguar OEM:
Vendor: JPAMPROSCHEJAGUARPARTS
Website: http://www.jpamporschejaguarparts.com
Front rotors $187.50
Rear rotors $174.38
Front Pads $121.13
rear Pads $96.94
Total: $579.95
Vendor: Autoparts Warehouse
Website: http://www.autopartswarehouse.com
Akebono Front Brake Pad Set Euro - Ceramic $109.24
Akebono Rear Brake Pad Set Euro - Ceramic $84.95
EBC Front Brake Disc 3GD Sport - Dimpled and slotted $198.41
EBC Rear Brake Disc 3GD Sport - Dimpled and slotted $158.51
Total: $551.11
Vendor: Brake World
Website: http://www.brakeworld.com/
Brembo Sport Rotors (Style: Drilled & Slotted) Front $252.00
Brembo Sport Rotors (Style: Drilled & Slotted) Rear $252.00
Disc Italia Hyper Ceramic Front $88.00
Disc Italia Hyper Ceramic Rear $85.00
Total $677.00
Vendor: Brake Performance
Website: http://brakeperformance.com/
PREMIUM DIMPLED & SLOTTED (SILVER) Front $187.56
PREMIUM DIMPLED & SLOTTED (SILVER) Rear $167.57
ceramic pads (semi metal free, upgrade to ceramic $20.00
Total: $375.13
Vendor: Auto Anything
website: http://www.autoanything.com/
EBC redstuff front pads $86.56
EBC redstuff rear $86.56
EBC Sport Rotors front $198.41
EBC Sport Rotors rear $158.51
total: $530.04
Clearly, the Brake Performance vendor is the cheapest, but does that mean lowest quality?
The Brembo has great reputation but are by far the most expensive.
I'm leaning towards the Akebono pads and the EBC rotors or the EBC rotors and the EBC redstuff pads; however, the Brake Performance site keeps calling to my miserly self!
Any opinions, thoughts, suggestions, warnings, other sites/ brands you recommend?
Old Nov 20, 2009 | 08:52 PM
Smeghead's Avatar
I installed Monroe ceramic pads and aftermaket rotors with the latest brake job. The pads came with shims, clips, and lubricant and I am very pleased with the performance and low dust level. IMO OE pads are spongey and dusty compared with the ceramics. I have not noticed any difference between OE and the various brands of rotors I have used. I do recommend new rotors with new pads.
I used EBC rotors and pads on my Infiniti once. I liked the pads alright but one of the rotors warped. Seems the price/value relationship is not so strong in rotors. One thing about cheap rotors is they seem to rust more but the difference is not worth the cost to me.
Old Nov 20, 2009 | 10:39 PM
reddrawf's Avatar
Thanks for the input. I still have not made an order.
By your name I'm guessing you are Red Dwarf fan too!
Old Nov 20, 2009 | 11:37 PM
I'd be interested to know why you would change the rotors unless they were worn below tolerance.
Old Nov 22, 2009 | 06:55 PM
FloridaJag's Avatar
Yeah. My theory is to replace rotors after 2 pad replacements or at 90,000 miles.
I plan on replacing my pads at 60,000 miles. I will likely go with ceramic pads due to brake dust issues.
Old Nov 23, 2009 | 01:11 PM
H20boy's Avatar
I've purchased rotors from brakeperformance, however, they were for my old jeep. Great rotors as far as I'm concerned. others have bought from them w/o any problem. I'd give'em a shot, and get the semi-metallics for free.
Old Nov 23, 2009 | 09:36 PM
reddrawf's Avatar
Thanks for all the comments!
I went for the Brakeperformance site. Dimpled and slotted rotors and the $20 upgrade to ceramic pads. Free shipping too. I'll report back when they arrive and I get them installed.
Old Dec 5, 2009 | 11:11 AM
reddrawf's Avatar
Talking Update
Rotors and pads arrived via UPS in 3 boxes. The rotors are heavy! Attached is a picture of one of the rotors.
Next step is to get these installed! I will probably do so the week of Christmas as I'll be in town all that week. I'll post an update when they are installed. I'd like to paint the calipers too, but doubt I'll be able to do so that week. Maybe.
Old Dec 5, 2009 | 01:48 PM
Smeghead's Avatar
While the rotors can usually make it through two sets of pads before reaching the wear limit, I have often experienced uneven wear or warpage while on the second set of pads. My preference is to insure the brakes will not need attention before they pads are needed again. The savings on my labor is worth the cost of rotors to me.
I only get around 40,000 on (front) pads- guess my wife brakes more aggressively than you guys. That could expalin why the rotors need replacement!
Forget if anyone has mentioned it but I suggest a tool to screw in the rear caliper pistons. Needle nosed pliers work but are a PITA.
I hope it is warm where you are red, I hate sitting on the cold concrete.
Smoke me a kipper....
Old Dec 20, 2009 | 04:16 PM
reddrawf's Avatar
Talking Update on Brakes!
Finally got the Jag to the Mechanic. He installed 4 rotors with pads for $300. He said he has never heard of www.brakeperformance.com but he said he was impressed with the quality of the rotors, especially for the price. He said the front pads did not exactly fit and he had to do a little grinding. The rotors look great and so far the pads seem to be working well. I have only driven a few miles to home ad then I washed the car and put some Poorboy's Wheel Sealant (http://www.poorboysworld.com/wheel-sealant.htm) on the rims to help with brake dust. I'm assuming that the first bit of use of the pads will have some dust.
Attached Thumbnails Need some advice on brakes!-dscn0009.jpg   Need some advice on brakes!-dscn0008.jpg   Need some advice on brakes!-dscn0007.jpg
Old Dec 21, 2009 | 10:07 AM
H20boy's Avatar
Looks good, how do they feel? You'll notice a TON less dust than the stock pads.
Old Dec 21, 2009 | 06:12 PM
reddrawf's Avatar
I have driven that much yet, but so far they feel better. The Jag stops more quickly. I'm getting more dust than before but I suspect that is because the pads are so new. The wheel sealant will help. Hopefully this coming weekend I can find time to clean the again and add another coat of the wheel sealant.
Old Dec 22, 2009 | 07:11 AM
joycesjag's Avatar
red, I painted my calipers in 2 hours (30 minutes ea.) I choose to paint factory silver and black. If you use those cheap 1" foam brushes and a modelers paint brush they go really quick!!
Attached Thumbnails Need some advice on brakes!-front-caliper.jpg   Need some advice on brakes!-joyces-jag-007.jpg
