Needing to replace power brake booster in 02 s-type 3.0 v6
Old Aug 20, 2012 | 03:03 PM
daboss085's Avatar
Default Needing to replace power brake booster in 02 s-type 3.0 v6
Can anyone tell me if I should go with a used oem or a cardone brand brand new off rockauto.com? Also, how much labor time to do a power brake booster? and does anything else need to be done while your in there? thanks guys!
Old Aug 20, 2012 | 07:17 PM
abonano's Avatar
How did you come to the determination that the brake booster needs to be replaced?
Old Aug 21, 2012 | 01:57 PM
daboss085's Avatar
I do need to do a inspection, but when I press the brake I hear a air sound, and sometimes when I press the brake I feel a grinding and a popping noise vibartion and feel it in my foot.
Old Aug 21, 2012 | 03:14 PM
abonano's Avatar
I believe there is a hose that runs off the brake booster that is prone to cracking/failing - I would trace the hoses off the brake booster. Search the forum on this. I'm no expert on the 3.0 but I do remember reading a thread about a leaking vacuum hose coming off the brake booster - if I come across it I will shoot it to you. Replacing a faulty hose is WAY cheaper than replacing a brake booster - let us know what you find.
Old Aug 22, 2012 | 04:40 AM
barney100golf's Avatar
Why would the brake Servo cause a grinding noise? does the car stop normally or does it seem to take a lot more pressure on the pedal to stop, generally but not always the pedal feels hard and stopping power is greatly reduced if it is a servo problem, check out the brake pads to see if they are worn, as this would more likely cause a grinding noise. If you have any concerns regarding your brakes I would suggest that you get them checked out as soon as possible.
Old Aug 22, 2012 | 05:03 AM
JagV8's Avatar
+1 to barney & abonano posts. (Yes there is such a pipe at least on some 3.0s)
Doberman_Fan
22
Dec 24, 2019 06:21 AM
tberry6686
Sep 20, 2015 03:22 PM
SD96XJ6L
Aug 29, 2015 03:20 PM
larney
Aug 27, 2015 07:54 PM
divingmom
Aug 25, 2015 07:54 PM
