new owner needs help
Old Jun 30, 2014 | 01:27 PM
phildog's Avatar
Default new owner needs help
hi all this is first jag, lovely car just a few small things spoiling it.no.1 heater not working.there is no water in the big hose to the left and low down from radiator could this be an airlock if so does anybody know how to bleed air out.
no.2 intermittent reversing sensors, could this be caused by over waxing?
I did have a blockage in windscreen washers found quick cure,An air duster to blow down washer pipes worked a treat.
As for air lock (if that is what it is )have tried bleed screw by expansion tank did not help thanks
Old Jul 1, 2014 | 08:04 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Originally Posted by phildog
hi all this is first jag lovely car just a few small things spoiling it heater not working.there is no water in the big hose to the left and low down from radiator
think this may be air lock dose anyone know how to bleed this air out also intermittent reversing sensors could this be caused by over waxing did have problem with windscreen washers being blocked took off front wheel removed pump cleaned that replaced worked fine for 10 mins bought air duster blew that down pipes primed pump with syringe no problem since.would like owners manual and wallet full set for 2005 diesel any one know where to acquire one any help would be appreciated but heater main prob will get there with the rest i have tried the bleed screw by expansion tank took of hose in the end but no joy thanks in advance cheers
welcome to the forum phildog may i suggest you include some punctuation in your messages as they are difficult to read without it you want as many members as possible to read and respond
Old Jul 1, 2014 | 09:03 AM
JagV8's Avatar
Must admit I gave up.
Old Jul 1, 2014 | 09:07 AM
phildog's Avatar
fair comment will give it a go but not my strong point
Old Jul 1, 2014 | 10:19 AM
sjgh's Avatar
Lol at the punctuation remark.
Would be most concerned of no coolant circulating thru radiator - if thats true - your engine is probably overheating? I am assuming you mean the orange coolant not water.
Do you know if the thermostat has been replaced recently? May want to check the coolant flow diagrams for your car to see which way the coolant flows.
Old Jul 1, 2014 | 01:29 PM
tbird6's Avatar
Just a suggestion but in the US we did not get the Diesel so the UK boards will have a lot more on your particular problems.
Have you posted on there?
Old Jul 1, 2014 | 02:42 PM
Mikey's Avatar
Hi all this is first jag, lovely car. Just a few small things spoiling it-
No.1, Heater not working. There is no water in the big hose to the left and low down from radiator. Could this be an airlock, if so does anybody know how to bleed air out? As for air lock (if that is what it is ) have tried bleed screw by expansion tank did not help thanks
No.2, Intermittent reversing sensors. Could this be caused by over waxing?
I did have a blockage in windscreen washers found quick cure, an air duster to blow down washer pipes, it worked a treat.
Above selfishly edited so that my eyes stop hurting
No.1, JTIS contains the procedure for bleeding the cooling system. I'm not sure if or how the diesel variants compare to gasoline powered versions.
No.2, the park assist system should emit an error tone if there is a fault. Does your car do this?
Old Jul 1, 2014 | 04:59 PM
phildog's Avatar
will try to bleed if no joy then try new thermostat
i do get error tone but only about half the time,no error tone parking assist works fine
Old Jul 1, 2014 | 05:55 PM
Mikey's Avatar
Next time you get an error tone, shut off the engine while the transmission is in reverse, set the parking brake and listen closely and carefully at each sensor in the bumper for a clicking sound. The one(s) that don't click are faulty.
Old Jul 2, 2014 | 02:18 PM
phildog's Avatar
jtis for bleed process and coolant flow diagrams can these be viewed on this forum if so where will i find them thanks.
captbob73
Oct 24, 2015 05:49 PM
Mean Gene
Sep 17, 2015 11:59 PM
ferraripete
Sep 16, 2015 03:42 AM
tampamark
Sep 14, 2015 09:12 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
