Nitrous powered 2003 STR
Old Nov 10, 2014 | 08:23 PM
MeanAzKitty's Avatar
Banned
Default Nitrous powered 2003 STR
So I've been on a 150 shot with over 40 bottles in her and she LOVES it...we are talking spinning on 60mph rolls. My question is do you guys think our str motors can handle a 200 shot on stock timing....I ask because people have ran 200 on stock timing on chargers and magnums.....I beat crotchrockets as is...just looking for an extra edge...what do you guys think about the design of our block....the 03 setup
Old Nov 10, 2014 | 08:27 PM
Banned
Default look me up....facebook.....jameson kilpatrick.....you will see white str
You guys can see some videos on my face book...there is supercharged vipers..bikes...maserati gran turismo s...347 mustangs..427tri power cobras
Old Nov 11, 2014 | 01:48 PM
XJR-99's Avatar
You already use quite a big shot. The block is strong and you have forged Mahle pistons and forged rods. What's your AFR when nitrous on and do you use some kind of nitrous controller?
Old Nov 11, 2014 | 03:38 PM
joycesjag's Avatar
Hey MeanKitty, good for you using the giggle juice! I think you caught the STR traditionalists (purists) with their pants down on this thread! I personally love it.
Although we own a "granny" 3.0, I read the STR threads. Once I had the audacity to mention giggle juice and boy did they go off. All I know, is if we owned an STR we would be laughing all the way to the finish line!
Old Nov 11, 2014 | 08:51 PM
grip grip's Avatar
What have you run in the 1/4 on the 150 shot???
Old Nov 13, 2014 | 01:51 AM
XJR-99's Avatar
Do not switch on 200hp shot too early or you are very slow
I would put ceramic coating to the pistons and combustion chambers as well as stronger piston rings if use 200hp shot or even more. NOS contoller and shots in two stages ( 100 + 100 ). Just my $0.02.
Old Nov 13, 2014 | 01:59 PM
1320racer's Avatar
Default Wow!
As far as I know, you've already broken new ground with a 150 shot. I have no advice, just questions and comments.
Please post:
Pics of the installation. Cooler plugs? Is nitrous injected before or after boost?
Update…Appears to be installed post supercharger
Pics of your time slips showing 1/4 mile ETs and trap speeds?
Pics of dyno sheets or Clips of dyno runs with Air Fuel ratio.
I'm wrong…I did not believe the transmission would hold the crazy torque you are likely seeing at the wheels. You must be around 450-490 foot pounds.
Old Nov 13, 2014 | 02:25 PM
tbird6's Avatar
You are pushing it for sure!
Let us know what breaks first.
Old Nov 13, 2014 | 02:51 PM
avos's Avatar
Sorry have no experience with NOS, let alone all the different systems around (wet/dry, controller types).
The engine itself is very strong, at least thats what I have seen so far with major mods.
Where do you spray? Pending on being it before or after the IAT2 sensor, it could be either safe or start to be unsafe. Iirc cold (so low IAT2 temps) the ignition timing is about 21 degrees, the hotter the charger to more retard, so spraying after you have more security, doing it before and the IAT2 becomes cooler and you will run possibly to advanced.
The only way to find out is to continue now with a 200 shot ;-)
One thing to remember though, I would guess that a weak spot would actually also be the gearbox. Even though it can handle lots of torque, it’s during the shifting that you could create issues.
Normally the TCM will ask the engine for torque reduction, and as the ECU doesn’t take the extra 200 into account, there is much more stress on the clutches.
So if you have a system that takes shifting into account, it will reduce again the extra risks.
Just my 0.02 euros.
Old Nov 13, 2014 | 08:21 PM
Wuzupez's Avatar
[QUOTE=XJR-99;1100064]Do not switch on 200hp shot too early or you are very slow
This guy needs some slicks & perhaps to be tubbed out! Good for him, looks fun!
Old Nov 13, 2014 | 08:34 PM
grip grip's Avatar
Great video. You definitely need DR's at least at the track if you're going to spray. Here's my old Crossfire on a 125 shot. Definitley would have done a half track burnout if not for tires. Sorry it's not a Jaguar, but I don't own one yet. If I end up with the STR, I'll definitely be tempted to run nitrous, since I have a wet kit in the garage.
Old Nov 13, 2014 | 10:39 PM
XJR-99's Avatar
[QUOTE=Wuzupez;1100748]
Jaguar STR (with Nos) vs Jaguar XFR (Stock) at Santa Pod in England May 2014 - YouTube
He needs LSD + DRs.
Old Nov 15, 2014 | 06:46 AM
XJR-99's Avatar
Old Nov 15, 2014 | 08:33 AM
hilaryv215's Avatar
Hi,
So user-member OneSicJag is handy with cars and actually built a racer and stuff maybe he could guild you in the right direction .
Good luck!
Old Nov 17, 2014 | 08:05 AM
1320racer's Avatar
Unless I misread your FB page, to see any of your plcs, I'd need to become your FB friend. Pls post some of your pictures and videos here so we all do not need to "friend" you on FB. Thanks :-)
Old Nov 18, 2014 | 09:57 AM
Banned
Hey guys to answer some questions its a NX ICEMAN EXORESS KIT,I am running Bosch iridium heat range 7...and I use O'Reillys full synthetic 5w30 I also run 91 octane with VP racing 110 leaded race gas...
Please post:
Old Nov 18, 2014 | 10:00 AM
Banned
Also just so you guys know the jaguar handled a 500 shot....I have videos of a race for 1000k dollars...it turned my exhaust tips white...I just sold the kit yesterday...she still runs strong and great! It was a 10sex car...and I won
Old Nov 18, 2014 | 10:03 AM
Banned
Also I ran a 13.12 at 116 on a 50 shot...one pass and I got kicked off....I beat 600rr street bikes tho...nice **** having a 10 or 11 sec jag!
Old Nov 18, 2014 | 10:13 AM
Banned
I made my Facebook public...for the last 3 months there's some pretty must videos of the jag on 150-200 and 500 shot...if anyone blows an str motor they are dumb..cause look what mine did
Old Nov 18, 2014 | 09:59 PM
grip grip's Avatar
Any photos of the 500 shot setup? The solenoids must have been beer can sized.
