no heat at idle
Old Nov 12, 2016 | 11:18 PM
Mark Yohn's Avatar
Default no heat at idle
ok guys sorry if this has already been brought up. new to jaguars. bought a 2000 s type 3 weeks ago and love it. here is the story. when its running and at idle i am not getting any air out of the vents. fan speed is all the way up and temp is on hi. when i am driving it i can feel heat coming out of the vents but at idle nothing. heated seats work good. any ideas on what it could be. is it a blower motor issue. few more questions also. want to put custom exhaust on. has a 4.0 in it and was thinking of flowmaster 40 series.
Old Nov 13, 2016 | 02:33 AM
Datsports's Avatar
i think your auxiliary coolant pump must have died . check your fuses first .
if its like mine the pump is mounted on the back of the cooling fan shroud behind the radiator . on a rubber mount .
Old Nov 21, 2016 | 04:41 PM
melhookv12's Avatar
Please confirm . You are getting no hot air or no air.
Hot air or cold air.
Hot air only when moving.
No air at all.
Hot air one side cold air the other.
Coolant level low or expansion tank cracked.
Auxiliary heater pump.
Engine water pump.
Is engine temperature gauge going up to normal.
