no heat when in drive.....
Old Dec 18, 2012 | 01:23 PM
  #41
willburn's Avatar
bump....im leaving in 45 min, I will be passing parts store and I want to replace this bad or wrong thermostat. Should we be using the alternate temp thermostat in these cars or in wisconsin? I have access to a 180deg thermostat or 192 (which was what i put in the other day and causes overheat). Please let me know asap if anyone knows....
Old Dec 18, 2012 | 02:23 PM
  #42
JagV8's Avatar
Generally just use the OE one.
  #43
bfsgross's Avatar
Use the stock temp thermostat which is 190 degrees or more.
Old Dec 23, 2012 | 10:31 AM
  #44
willburn's Avatar
Default Fixed...
Dccv valve gave the car heat. I have no theremostat in yet, and still working on the "3 day bleeds" overnight everynight. But I think we are ok. I was getting blazing hot 125-130 deg F heat out of vents last night. Let it set overnight to bleed itself, going out this morning to top off and heat up again.
It still was starting to kick the radiator fan on last night during bleeding. I hope the waterpump isnt next...it does seem to have better heat during acceleration and over 2000 rpms versus idling.
Old Dec 23, 2012 | 01:54 PM
  #45
NBCat's Avatar
Glad to see you have heat after replacing the DCCV and bleeding.
Once the thermostat is installed and the system completely purged of air, you should have consistent heat at all engine speeds.
Old Dec 23, 2012 | 03:30 PM
  #46
Gus's Avatar
Gus
Kudos to you!
Old Dec 23, 2012 | 05:31 PM
  #47
bfsgross's Avatar
Good job Will. "The Heat is On" (Glenn Frey (Eagles)
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
