No sound radio
Old Dec 2, 2014 | 11:53 PM
Hec's Avatar
Hec
Default No sound radio
2003 S-Type
radio cant find station just keeps scrolling thru stations when search button pressed, and no sound in am or fm. Any help would be appreciated.
Old Dec 3, 2014 | 02:02 AM
Welcome to the forum HEC,
I've moved your question from General Tech Help to S-Type forum and deleted the duplicate from Jaguar Forums Feedback & Suggestion Center.
Members here with the same model will be able to help.
Old Dec 3, 2014 | 06:18 AM
I see from your Intro that there's more than just the radio not working properly.
This is the battery reconnection procedure from JTIS (Jaguar Technical Information System - the workshop manual):
CAUTION: Make sure all electrical systems are off before connecting the battery negative cable. Failure to follow these instructions may result in damage to the electrical system.
Following battery disconnection the engine should be allowed to idle as the stored idle and drive values contained within the engine control module (ECM) have been lost. This may cause driveablity concern if the following procedure is not carried out.
1. Connect the battery negative cable.Tighten to 4 Nm
2. Start the engine and allow to idle until the engine reaches normal operating temperature
3. Switch the engine off
4. Restart the engine and allow to idle for approximately two minutes (this will allow the ECM to learn the idle values)
5. Apply and hold the brake pedal, select drive and allow the engine to idle for a further two minutes.
6. Drive the vehicle for approximately five miles/eight kilometers of varied driving to enable the ECM to complete it's learning strategy
7. Reset the audio unit and climate control assembly to original settings
philwarner
Oct 4, 2024 01:37 PM
pilot435
Apr 8, 2016 06:16 PM
al_roethlisberger
Sep 21, 2015 08:15 PM
Lannyl81
Sep 20, 2015 08:56 PM
Burdedw
Sep 12, 2015 10:39 AM
