Noisy door trims
Old Jun 19, 2008 | 12:10 PM
cosworth's Avatar
Default RE: Noisy door trims
Make sure the windows seals are in the correct place. Look at both sides of the car to compare. I tracked down a stubborn wind noise to a ill fitted window rubber.
Old Jun 19, 2008 | 04:33 PM
cosworth's Avatar
Remove the rubber from inside the door handle.Remove the two screws. Then pry the door release surround off GENTLY. Once this is done the door panel simply pops off with a bit of a grunt. Grab from the bottom first.
Once in there, check the seal is intact and replace with gaffer tape accordingly. Clean both surfaces then get an old candle and rub the door panel and door where they join. Put the door panel back on making absolutely sure every white male locator pin mates with it's female locator. Give it a bang every 6 inches with a rubber mallet or your fist to make sure it's tight as possible.
Put the screws back in and reinstall the door release surround.
This should solve any squeaking for some time.
Old Jun 19, 2008 | 06:59 PM
ibjags's Avatar
Lulette
make sure you remove the interior door handle trim also before you pull that door panel off
Old Jun 19, 2008 | 10:52 PM
cosworth's Avatar
Funny but I did mention that...
Jose
Dec 18, 2021 08:16 AM
hologram1954
Sep 16, 2015 02:43 AM
SeanU
Sep 14, 2015 04:31 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
