Are the O2 and temp censors the same on the 03 Thunder bird V8 and 03 S-type
Old Sep 22, 2011 | 04:40 AM
catniped's Avatar
Banned
Default Are the O2 and temp censors the same on the 03 Thunder bird V8 and 03 S-type
I need to know if the O2, air temp, and mass air flow censors are the same if not similar on the V8 Thunder bird and the S-type Jag.
I didn't get to in depth with my research so correct me if I'm wrong. I found out the thunder bird and the Lincoln LS share the same engine in 2003 there for you can use the same intake parts between the two.
I have also been told by someone on this forum that the 4.2 Jag V8 is a beefed up version of the Lincoln LS V8. So my theory is I should be able to use the cold air intake that K&N makes for the Thunder bird on my Jag.
kaotikd
76
May 24, 2016 02:23 PM
ssshield
Sep 24, 2015 08:29 PM
rasputin
Jul 21, 2015 11:02 PM
keepinitoldskool
Jul 4, 2015 11:54 AM
