Oddly no start
Old Jun 28, 2012 | 05:30 PM
Namor's Avatar
Default Oddly no start
2000 3.0 with around 134k miles. The car has been starting without an issue. The a/c is out so I hooked the gauges up to see where I was on the 132 since the clutch on the compressor was not coming on. In the mean time I also swapped the Throttle control relay with the clutch relay just for a relay swap.
I went to start the car and the idle went nasty between 400-1,200 rpms then died. It did this a couple of times. Now it won't start at all. It turns over but doesn't run.
Relays have been returned to original location
I have spark
Plugs are good
Pressure in the fuel rail
Good relays and fuses
Good battery
Car will not run on carb spray so I ruled out fuel issue. The engine will run for 1 second with carb spray (yes I am not spraying the MAS) but refuses to run.
No DTCs
... and no warning. Anyone have an idea where to go?
Old Jun 28, 2012 | 05:41 PM
JagV8's Avatar
I'm guessing either you disturbed something (causing vacuum leak or a chafed wire to short or a poor connector to quit or ...) or a sensor chose that moment to go bad. Would have to be a critical one such as CKP or ECT.
Worth checking no damp/water in trunk, too.
If I were guessing a sensor it would be CKP. (If you can, scope it.)
Old Jun 28, 2012 | 07:32 PM
Namor's Avatar
I've gone over everything I touched, not much of anything, and I don't see anywhere where I jostled or chaffed anything.
I think the CKP is a good guess given that they fail and don't give a trouble code warning. But, I would have expected it to show symptoms of pending failure.
I will check it out in the morning.
In the meantime, does anyone else have a suggestion?
Old Jun 29, 2012 | 10:20 AM
Digiorno's Avatar
Confirmed that it is not the CKP
Old Jun 29, 2012 | 10:24 AM
JagV8's Avatar
There's a lot still to check. If you need inspiration there are lengthy previous threads with details and pointers to step-by-step PDFs.
Scarecrow
Mar 28, 2016 03:17 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
carelm
Sep 5, 2015 01:13 AM
King Charles
Sep 3, 2015 12:40 AM
