oil cooler lines leaking on 03 STR.......
Old Feb 16, 2010 | 10:05 AM
phd12volt's Avatar
Default oil cooler lines leaking on 03 STR.......
i am having a small leak noticable from the compression fitting, any idea on ease of replacement??? Also i called the dealer for parts, and i was told there are 2 parts. Inlet and Outlet. Should i do both at 1 time or just the one that is leaking? Also it is the one that is inbetween the alternator and radiator. Which one is that considered? Any help would be appreciated.
Old Feb 20, 2010 | 09:31 PM
Teck4Jag's Avatar
i would do both,since they are both the same age and been through the same amount of heat cycles
Old Feb 23, 2010 | 12:34 PM
phd12volt's Avatar
Thanks for the response, im pretty good with cars, is this something i should take in or something i can do myself?? the parts are exactly the same price. Anything major with the replacment?? and is this fairly common??
Old Feb 24, 2010 | 10:18 AM
Fraser Mitchell's Avatar
I would say this is something you can do yourself, assuming you are taking out old hoses and putting in new ones. You need to be very careful as you will have to crawl under the car to replace them, so don't take any risks - Jaguars are very heavy ! Car needs to be on strong ramps and not held on a jack. But you know this already, no doubt !
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
Scarecrow
Mar 28, 2016 03:17 AM
Dymaxxion
Sep 4, 2015 02:40 PM
