Oil leak
Old Nov 26, 2023 | 01:07 PM
SaintNZ's Avatar
Default Oil leak
Hi there,My 03 STR has an oil leak appears to come from above the oil filter. I think It's likely to come from the oil line.
Before I take it a part, is it likely to be a oil ring or gasket?
Old Nov 27, 2023 | 10:57 AM
clubairth1's Avatar
Community Influencer
Hard to say without any pictures?
I would clean everything up good and watch where the oil is coming from.
On my STR I had the oil cooler lines weeping where the rubber hose is crimped onto the metal tube. Hard to see because as the oil weeps out the air flow throws it all over the front of the engine. My fix was to cut off the metal crimp and replace the rubber hose reusing the factory steel tubes and adding 2 clamps per connection. Never had a problem after that.
Old Nov 27, 2023 | 11:08 AM
scottjh9's Avatar
Like club says clean up the area real good. Then get it up high enough to run the engine and look. I found the oil filter adapter plate leaking on my 06 str. There is also the front crank seal and lower timing cover gasket as a possibility if coming above the oil filter. The 03 and 06 have different oil cooler setups so i am not familiar with the hose routing. If club saiys check yours then he definitely knows for sure. I now have a small nuisance leak at the bottom of the timing cover myself.
Old Nov 28, 2023 | 12:19 PM
clubairth1's Avatar
More good suggestions!
Post back what you find to help the rest of us.
Old Nov 29, 2023 | 08:36 AM
kr98664's Avatar
Does this parts diagram help? Perhaps gasket #2?:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Dec 19, 2023 | 08:27 PM
SaintNZ's Avatar
Thanks for all the help.
The metal line connecting to the oil filter housing above the filter has a o ring seal that I replaced. there is still oil coming for somewhere but this stopped the majority of the leak....
ray13
Mar 28, 2023 07:18 PM
Gilxj695
Jan 25, 2023 12:40 PM
perfectphoto
Dec 16, 2021 07:14 PM
disguay
Dec 20, 2011 05:33 AM
kevin2050
Aug 29, 2011 12:15 PM
