oil leak
Old Nov 1, 2012 | 08:33 AM
Styping's Avatar
Default oil leak
I have a 2001 s type, 3.0.... Oil from my upper intake port is leaking onto my exhaust and causing it to smoke when its hot. When i stop at a stop light or so, smoke temporarily fills the cars and smells. What would be the fix for that? Is it a gasket inside the intake port?
Old Nov 1, 2012 | 09:54 AM
Jon89's Avatar
Yes. The two intake manifold tuner valves (upper and lower) have yellow-colored O-rings that tend to fail on every V6 engine. The fix is to replace them with the new-and-improved green-colored O-rings. They are thicker, rounder, and create a leakproof seal. There are many threads on this forum that will take you through the installation process. Simply search "intake manifold tuner O-rings" and you'll find all the information you need to know to do the job yourself. The two new O-rings should cost between five and ten bucks, total, at the Jaguar dealership....
Old Nov 2, 2012 | 10:55 AM
Styping's Avatar
Thanx! I will search for the instillation solution in the forums.
Old Nov 2, 2012 | 11:12 AM
joycesjag's Avatar
I'll help you along:
https://www.jaguarforums.com/forum/s...ics-faq-32135/
and if you miss the link in the opening paragraph:
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
