Oil leaking from vacuum pump gasket
Old Jun 16, 2020 | 06:21 AM
Stuart Satter's Avatar
Default Oil leaking from vacuum pump gasket
Anybody know where to buy the gasket for this? It works, just leaks and Jaguar is over priced at $500 a part. Just ridiculous.
see pic
Old Jun 16, 2020 | 09:32 AM
NBCat's Avatar
Vehicle details? Such as MY and engine fitted; number of kilometres/miles on the vehicle?
Old Jun 17, 2020 | 09:32 AM
clubairth1's Avatar
Community Influencer
I think he is in the wrong place???
I "believe" that is the gear driven vacuum pump on the 5.0L V-8?
Stuart please do some searches as this has been answered before. Yes you can just replace the O-ring BUT be aware that many people have found this cover to have loose bolts.
So your repair may be very simple and cheap?
Best to get the car on a lift and remove belly pans for easy access.
Also do NOT delay fixing this!! We have had at least one member destroy his engine because so much oil leaked out of the vacuum pump.
With the number of belly pans on this car you might not ever see anything on the ground when parking.
It could be building up and then blown out when the car is moving at speed.
Old Jun 18, 2020 | 12:52 PM
S-Type Owner's Avatar
I believe you are correct. Quite a few of the OP's posts are in the F-type forum...
Old Sep 13, 2020 | 02:01 PM
trkyam's Avatar
which bolts should I tighten, the 4 hex bolts or the 2 regular bolts?
Old Sep 18, 2020 | 03:10 PM
trkyam's Avatar
Its the 2 regular bolts, or larger hex bolts depending on what year you have..
eomall3754
Mar 2, 2020 08:00 PM
Kleman
Feb 5, 2015 01:53 AM
pdupler
Nov 9, 2014 11:44 PM
ChrisX
Jan 20, 2009 01:46 PM
hey_hej
Apr 16, 2008 09:19 AM
