Oil in lower IMT housing
Old Mar 14, 2009 | 02:36 PM
joycesjag's Avatar
Default Oil in lower IMT housing
Is this normal? If not, any ideas where it would be coming from.
Thank you goduars (get it)(I kinda like that one)
Old Mar 14, 2009 | 03:24 PM
Brutal's Avatar
normal, make sure youre using the new style green orings. They seal much better, we at the shop are also now working on different ideas to reduce this since I believe its the number 1 cause for misfires on cylinders 1,3,5 which are fed by the lower intake. When the oil vapor which comes from the crankcase goes through the intake it settles out in the lower plenum as your pics show, when it becomes heavy enough, it cause misfires on these cylinders. The things Ive been working on with a couple customers is switching to a 40w oil, cleaning the intake passages, and as of yesturday 1 customer is going to start using engine restore to increase ring seal and reduce blowby. All are much cheaper and better fixes so far than thowing in 3 coils, plugs and shipping..especially since it always involves removal of the intake and subsequent labor fees
Old Mar 14, 2009 | 04:43 PM
joycesjag's Avatar
Thank you Brutal !!!!
You just made my weekend. I thought there might be a major issue going on.
Phewwww
wheres my cold 1
silkcat
Jan 18, 2025 04:29 AM
Wahooesprit
Dec 23, 2019 02:01 PM
GordoCatCar
Jan 2, 2017 01:10 PM
SCMike
Sep 22, 2015 07:34 PM
1964Daimler
Sep 9, 2015 11:28 AM
