Over heating
Old Aug 15, 2024 | 12:14 PM
07jags's Avatar
Default Over heating
O7 jaguar stype started leaking coolant and then stopped. It's overheating driving more then 15 minutes.
Old Aug 15, 2024 | 01:37 PM
sov211's Avatar
If you continue driving while the engine is overheating you are doing serious damage! You MUST find where the coolant is leaking from (hoses, coolant reservoir, water pump ….?) and have it properly repaired.
Old Aug 15, 2024 | 05:55 PM
NBCat's Avatar
With the engine cold, use a cooling pressure tester to pressurise the cooling system to 1 bar. Check for leaks and evidence of dried coolant to find the leak(s).
If the engine is operated under conditions that cause it to overheat, head gasket failure is the likely result.
Old Aug 15, 2024 | 06:32 PM
scottjh9's Avatar
Ok. Brief history of problem and year and model and engine will help us alot to help you
jt20
Dec 26, 2024 11:32 AM
bazza13
Apr 21, 2017 06:15 AM
bazza13
Apr 20, 2017 08:26 AM
ATerry
Apr 16, 2009 12:54 PM
Nov 5, 2006 12:06 PM
