Over heating
Old Nov 9, 2024 | 04:40 PM
Wild Cat's Avatar
Default Over heating
My 2000 3.0 started over heating. Turned out several hoses had small tears Fixed them and the car was still overheating and we found the water pump to be weeping. We also found the upper radiator inlet cracked.To pull the radiator we literally had to disassemble every thing in front os the motor. 15 hours later it was done along with the heater control valve. Next week is plugs. The job was a nightmare but at least I shouldn't have any cooling system worries.Also fixed a headlight lens break from a large bird. I found an assembly and we were able to get them both apart and to switch lenses As I said,, the whole job was a bitch!!!
Old Nov 11, 2024 | 04:00 AM
Beretta9's Avatar
Radiator is not fun on these s types. Did you need to pull the bumper to replace the headlight lens?
Old Nov 11, 2024 | 11:11 AM
Wild Cat's Avatar
Yes We pulled the bumper cover and bumper 'beam" behind it and also disconnected the condenser so we could move. it out of the way. This. is not for the faint of heart
Old Nov 17, 2024 | 12:20 PM
davidladewig's Avatar
When I bought my Jag, I started buying all new hoses so as I had time, I could change them. The worst cooling defect on all these cars is the expansion tank. That was the number one complaint for 4 years. Plastic timing tensioners was second but managed to move to first place once the early models got a few miles on them. Jag has suspended all car production.....looks like they might belly up soon. That said, stock up on parts now.
Mcthisle
General Tech Help
Jun 15, 2024 06:04 AM
alabbasi
Dec 4, 2018 08:08 AM
1964Daimler
Aug 7, 2016 05:18 PM
S.Typer
Aug 4, 2011 12:58 PM
