P0171 and P0174
Old Dec 11, 2013 | 08:29 AM
  #81
nail24fac's Avatar
Repair of the airbox and replacing MAF sensor seem to have solved the problem. Drove on a 250 mile trip at various speeds and no faults. Trims are moving toward 0. I'm off to repair the the sunroof cassette on my BMW 528i. Merry Christmas to all and to all a good night.
Old Dec 12, 2013 | 05:06 AM
  #82
hombre_101277's Avatar
Originally Posted by JagV8
So read and post the LTFTs. How can anyone give advice without proper data...
I will give the fuel trims trims by tomorrow , I beat they will e a bit high.
Thank you jag V8.
Old Dec 13, 2013 | 05:32 AM
  #83
JagV8's Avatar
Go for it! Hopefully it's now fixed but they'll show if not.
Old Dec 30, 2013 | 12:29 PM
  #84
nail24fac's Avatar
I'm back from a trip to Florida and back. No codes or ECL. Over 1000 miles plus. Until the next time, this thread is closed for me.
Old Dec 31, 2013 | 05:15 AM
  #85
Emil and restrict performance back again, fuel trims high over 10. Can not find reason why ??? As I said we have done a smoke test, check engine breather valve, changed Maf, etc,,,, it is seems like there is a hissing noise , something like too much air goes in to engine , is there any other valve inside somewhere that may doesn't work properly ????
Old Dec 31, 2013 | 06:06 AM
  #86
JagV8's Avatar
Do the trims drop when you rev to 2500?
Old Jan 1, 2014 | 07:24 AM
  #87
Happy new year to all of you !!!!!!!
Old Jan 1, 2014 | 08:57 AM
  #88
nail24fac's Avatar
MAF sensor ended up fixing mine. Check the O ring seal on it.
Old Jan 1, 2014 | 10:26 AM
  #89
JagV8's Avatar
Check and report on trims instead of changing any parts. Far cheaper.
Old Jan 8, 2014 | 02:32 PM
  #90
Eml and restrict perform back again, after all testing made snake test, maf replacement , etc I may think only thing left can be EGR or can it be anything else ?please advise as this annoying
Old Jan 8, 2014 | 02:42 PM
  #91
JagV8's Avatar
Please read and take heed of previous advice.
Old Jan 8, 2014 | 06:10 PM
  #92
Brutal's Avatar
And i can say the "new" issue coming up on the 4.2 v8s with plastic and aluminum intakes. Where the plastic joints the lower injection manifold they leak and leak bad. The orings are not avail seperatly and a new intake is $1200+. Ive worked on taking apart and sealing with rtv and has not responded as i would have liked. The second one is back a day later. Resealed and try again. Maybe one of you industrious owners can source these orings...
Old Jan 8, 2014 | 06:50 PM
  #93
Gus's Avatar
Gus
Are you talking about this seal?
Link Jaguar Air Intake Manifold to Adapter Plate Upper Gasket Reseal Kit 2004 2009 | eBay
Old Jan 9, 2014 | 12:13 PM
  #94
tbird6's Avatar
Great find! Sure looks like the right ones.
Old Jan 9, 2014 | 05:23 PM
  #95
Brutal's Avatar
Yes thats them gus, and ive now ordered some rover ones as they look the same in the catalog. Why rover supplies and jaguar doesnt......???
Old Jan 10, 2014 | 07:48 AM
  #96
Brutal's Avatar
And this guy euromark is here in houston, and going through our business accounts he is the business that buys all the rover seals we can get and then marks them up over list and resells on ebay. Soooo long story short, you can probobly get them cheaper from a rover dealer. Ps i also see him selling arnot shocks a couple hundred over thier cost. Man maybe i need to just be a ebay seller and quit here.
Old Feb 2, 2014 | 08:37 AM
  #97
Can it be the EGR causing the lean bank 1 and 2 ? Please reply
Old Feb 2, 2014 | 10:04 AM
  #98
JagV8's Avatar
What about actual OBD values instead of expensive guesswork?
Old Feb 3, 2014 | 11:59 PM
  #99
High fuel trims, smoke test was done , air leak is not present, maf sensor swaped from another jag, so it is not that one , air box checked and all ok, that
is why I presume egr valve can give lean bank 1 and 2
Please help!
Old Feb 4, 2014 | 02:27 AM
  #100
JagV8's Avatar
Use diagnostics better.
