P0171/P0174 Diagnostic Test Code '07 STR (66km)
Old Oct 8, 2015 | 08:22 PM
Ragn0r's Avatar
Default P0171/P0174 Diagnostic Test Code '07 STR (66km)
2007 Jaguar S-Type R (66km)
So I would like to share my experience with Bank 1 (P0171) Bank 2 (P0174) Diagnostic Test Code (DTC) 'System to lean' from Dash Command. Upon investigation the first time there was a vacuum hose with a 90° elbow that had come off the metal nipple just behind the throttle body. Reattached and lean codes went away. A week later the same issue cropped up so this time I applied a thin coat of high-temp black RTV to the metal nipple and slid the 90° elbow on and cinched the nipple with two black ty-wraps. As in the attached picture
Attached Thumbnails P0171/P0174 Diagnostic Test Code '07 STR (66km)-vacuum-leak.jpg
Old Oct 9, 2015 | 02:21 AM
JagV8's Avatar
That's "too lean"...
Old Oct 18, 2015 | 09:35 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Has this resolved your problem?
Old Oct 18, 2015 | 07:31 PM
Ragn0r's Avatar
Yes. So far the vacuum hose has not slipped off. Thank you for asking.
Old Oct 19, 2015 | 12:17 PM
tbird6's Avatar
Keep an eye on the P/B booster vacuum line. The O-ring seal degrades with heat and time and this is a very common vacuum leak point on STR's.
Russ Graber
Feb 23, 2019 11:59 AM
ZJag
26
Sep 5, 2016 03:33 PM
Armor6
Sep 14, 2015 07:56 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Javier Cepeda
Aug 29, 2015 12:50 PM
