P0174 -System too lean (Bank 2). Help me with the Freeze frame data.
Old Apr 2, 2012 | 08:38 PM
03JagSType3.0's Avatar
Question P0174 -System too lean (Bank 2). Help me with the Freeze frame data.
My dreaded P0174 code popped up again. I thought I had this fixed when I found a cracked hose that connects the PCV Vacuum line into the intake. I replaced the rubber piece, cleared the code, and went a week and half before it popped up again.
I have inspected all the hoses according to post below and don't see anything wrong with the other hoses. This weekend I will take a better look when I do the 100,xxx mile maintenance on the Jag (replace sparks, coils, upper and lower intake seals, fuel filter, cabin and air filter, and oil change).
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Can anything from the data below indicate the problem? Like perhaps the o2 sensor is bad?
Freeze Frame Data:
Fuel Sys 1 - CL
Fuel Sys 2 - CL
Calc LOAD (%) - 49.8
ECT (F) - 204
STFT B1 (%) - 25
LIFT B1 (%) - 6.2
STFT B2 (%) - 24.2
LIFT B2 (%) - 7.8
Fuel Pres (PSI) - 53.5
MAP(inHg) - 27.4
Eng RPM - 2055
Veh Speed (mph) - 21
IAT (F) - 89
MAP (lb/min) - 4.750
TPS (%) - 34.9
Any help would greatly be appreciated.
Old Apr 2, 2012 | 09:11 PM
joycesjag's Avatar
Do your "tune up" first, then see what happens. My guess is that once you replace the IMT O-rings you may be pleasantly surprised.
Old Apr 2, 2012 | 09:32 PM
Thanks Rick for the reply back.
I forgot to mention in my post, I replaced the IMT O-rings when I replaced the cracked hose described in my original post (about two weeks ago). I didn't have the time to remove the intake at that time so I used the short method.
Old Apr 2, 2012 | 09:40 PM
joycesjag's Avatar
With the mileage on your 2003 you might get luck then with the upper and lower intake gaskets.
In the "90k mileage thread" you read, that was a big factor in Joels vehicle. Two of the lower intakes were leaking.
Old Apr 2, 2012 | 09:46 PM
Good to know. I will update the thread this weekend after I do the maintenance.
Thanks again Rick!
Old Apr 3, 2012 | 02:23 AM
JagV8's Avatar
Misfires are inevitably also lean conditions as there are O2 sensors which see the unused air.
Old Apr 4, 2012 | 12:47 PM
Just an update, the check engine light was off this morning when I drove to work.
Still doing the 100,000 maintenance this weekend and ordered a valve cover gasket just in case.
CXJ
Aug 29, 2017 08:41 AM
carl purchase
Oct 14, 2015 06:14 PM
brgjag
Oct 6, 2015 09:27 PM
sdelliott58
Sep 28, 2015 11:21 PM
