P0304 Misfire
Old Dec 31, 2008 | 09:03 PM
Stevil's Avatar
Default P0304 Misfire
I posted in an earlier thread I was suffering from erratic idle, and stumbling acceleration, well the Check Engine Light finally came on, P0304. Misfire in cylinder 4, so my question is (don't laugh) which side is cylinder 4 on, drivers or passenger? I figure I need to check/change the coil or plug right?
Old Dec 31, 2008 | 10:06 PM
Brutal's Avatar
Default RE: P0304 Misfire
v6 or 8? NEI( not enough information)
Old Dec 31, 2008 | 11:00 PM
Stevil's Avatar
Doh, my bad... V8 2001
Old Jan 1, 2009 | 12:10 AM
ArmyJag's Avatar
Standing in front of car and looking back at windshield - starting from front: 1,2,3,4 on the right and 5,6,7,8 on the left.
This was found through google so I'm not positive that I'm correct. Hope it helps
Old Jan 1, 2009 | 02:26 AM
Stevil's Avatar
I googled some but found a lot of conflicting info. [sm=insomnia.gif]
Old Jan 1, 2009 | 09:07 AM
ArmyJag's Avatar
http://autorepair.about.com/library/...bl-fo-1655.htm
I'm hoping someone comes along with better knowledge than us google warriors lol. Here is one with a diagram I've found this one a few times but it really doesn't seem to be of much help since it lists 2 cylinder 4's
Old Jan 1, 2009 | 09:55 AM
Brutal's Avatar
think Uk where they drive on the "other" side of the car so thats how theyre numbered. US left hand drive #4 is back right passenger side, when you see 2 1-4numbering A bank is the passenger side on US cars, B bank driver so 1-4 on the pass side front to rear, and 5-8 drivers side front to rear. same with all bank numbering. the predominate bank is A or 1, and always on the passenger side for US, its the DRIVERS side(right hand) for UK are you confused now
Old Jan 1, 2009 | 11:07 AM
ArmyJag's Avatar
Yup completely
Actually no it makes sense I just wasn't sure which bank was the 1-4 and 5-8 your explanation clears that up.
Brutal, Little off topic but I really like the rims on your Jag those look awesome on it don't suppose they fit a xj40? If so what year did you get those off of?
Old Jan 1, 2009 | 02:04 PM
Stevil's Avatar
Being a Limey living in the US that all makes sense, or as we say it... eighteen pence. Outstanding, #4 or 1-4 last cylinder at the back passenger side (US) looking at the engine from the front. Now I've just got to figure how to get at the coil, cheers fellas... Happy New Year!
Old Jan 1, 2009 | 03:44 PM
ArmyJag's Avatar
Ignition Coil-On-PlugLeft and Right-Hand Bank Disconnect the battery ground cable. Remove the engine cover. Left-Hand BankRemove the evaporative emission canister purge valve. For additional information, refer to Remove the oil level indicator. Detach the power assisted steering fluid reservoir. Unclip the engine breather hose.
Right-Hand BankRemove the air intake tube. For additional information, refer to Left and Right-Hand Bank Left-hand bank shown, right-hand similar.
Remove the ignition coil cover. Disconnect the ignition coil electrical connector. Remove the ignition coil. To install, reverse the removal procedure.
Straight out of the JTIS, if you would like a copy of the JTIS Program pm Christo and he'll hook you up with the download link. It has all the fun info on your Jag.
Old Jan 2, 2009 | 04:40 PM
Stevil's Avatar
Thank you, didn't realize I had to take the whole cover off, thought the smaller one would do it... oh well.
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Norri
19
Sep 28, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
