P0355, Crank Shaft Sensor
Old Nov 16, 2018 | 02:59 AM
racJAG204's Avatar
Default P0355, Crank Shaft Sensor
2004, Jaguar, S-Type, 3.0L, 227K, (USA))
Recently experience a long crank (no start), Diagnosed as a failed fuel pump. I replaced the main fuel pump but now have CEL with a code P0335 (Crankshaft Sensor Position A malfunction). I would like to know the location of the sensor or sensor(s) if more than one. I could not find any information for replacement on my JAG. I am not sure how difficult it would be to replace myself or should I have a trusted mechanic to perform for me, Thanks for any advice that is provided. RAC's Grey JAG S-type 3.0
Old Nov 16, 2018 | 10:32 AM
S-Type Owner's Avatar
The crankshaft position sensor on the V6 is located on the front of the engine, down near the crankshaft pulley. Whether you should attempt to replace the sensor depends on your level of skill and what's in your toolbox. As noted above, the sensor is located in a bit of an awkward spot, but it is not a challenging item to replace, The factory workshop manual is available for download on line:
http://www.jagrepair.com/JaguarSType...OBDIIcodes.htm
Old Nov 18, 2018 | 08:37 AM
racJAG204's Avatar
Thank you S-Type Owner.
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
terebyte
Oct 21, 2016 05:47 PM
Lord Donnington
Oct 20, 2016 03:12 AM
Jeff DeVere
Oct 13, 2016 07:00 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
