P0430 Cat threshold Bank 2 code, need some help.
Old Mar 26, 2023 | 08:33 AM
kr98664's Avatar
Originally Posted by Aarcuda
the entenders ere easily spotted. No cars come with them.
I’ve got one exception for you. A friend had a Nissan pickup (2000?) that was throwing a P0420 code when still under warranty. Nissan had a service bulletin to install a spacer on the downstream O2 sensor. Not sure if this was a recall or not.
He had the spacer installed by the dealer and all was good. No under vehicle inspection here unless the vehicle fails and you try to get a waiver. I’m guessing Nissan must have provided some documentation to verify this was a factory-approved modification, or it would fail a visual inspection.
Old Mar 13, 2024 | 09:12 AM
davidlqs's Avatar
Thanks for all the input, up to now I've been reading comments like "it won't be the cats, it'll be sensors" or "the cats will only fail if physically damaged or you've got another engine problem (oil leak / coolant leak / bad fuel mixture". Experiences here seem to be at odds with those beliefs.
The mechanic I took the car to suggested I try this outfit as a possible cost-saving:
Escapes La Cumbre Racing | Car & Motorcycle Exhaust Pipes
They claim to have a process for regenerating cats, that seems to involve cutting the old ones open, inserting some sort of rolled up impregnated metal material into the enclosure, then welding it back together. Sounds a bit Heath-Robinson to me, but what do I know? I was considering getting something like a Magnaflow or Paramount unit shipped out to Spain (if that's even possible), but if this regeneration idea isn't completely crackers I might give it a try.
Old Jan 29, 2025 | 09:25 AM
guy's Avatar
guy
Sure…. But when the CATS are done, they’re done.
Give Mother Nature (and your car) a break and just replace them, already.
I’m on my 3rd set on the XKR. Just like tires, this is the Cost of Ownership if you like the sound of the revving engine and consider the red line the shift indicator.
vegang
Mar 24, 2023 07:44 AM
bobhoff
Jun 30, 2017 05:04 AM
hliberman
Jul 16, 2014 05:30 PM
darren-talbot
Jan 17, 2013 02:42 PM
daboss085
Sep 22, 2012 10:03 PM
