p1000...
Old May 25, 2011 | 11:04 PM
dom08's Avatar
Default p1000...
hey guys
ijust replaced a rad. hose... now i am getting a p1000 code... it will not erase... the car will not rev, gear box, abs...etc lights are on...
how do i go about erasing this code?
thanks alot
Dom08
Old May 25, 2011 | 11:11 PM
sparkenzap's Avatar
dom:
You could check the archives- P1000 means that you have not completed the OBD drive cycle since a reset- You cannot "erase" p1000. reset causes it.
Old May 25, 2011 | 11:12 PM
mohrd's Avatar
P1000 is okay. Just means the ECM hasn't reset yet. Drive around and it shouldn't be long before you've done enough speed changes etc that a "drive cycle" will be complete.
Sounds like you've got other issues. the car will not rev, gear box, abs...etc lights are on...did you reconnect everything you had disconnected or jostle something loose?
Old May 25, 2011 | 11:19 PM
dom08's Avatar
thats the issue..... i cant drive... it wont allow the car to rev over 1500 rmp (or so).
should i just roll around the driveway with it and see if it clears it?
it also shows DCS not available, parkbrake fault, engine system fault.....
nothing else was touched, just changed the hose.... everything was running fine before.
Old May 26, 2011 | 12:10 AM
dom08's Avatar
wow.... is my face red..the truth... bottom throttle body wasnt plugged in..... but im going to lie and say "it just reset itself!"
thanks alot guys i really appreciate your help... please excuse my stupidity
Old May 26, 2011 | 12:21 AM
sparkenzap's Avatar
Dom:
Glad you found it.
None of us who work on our cars are immune from that kind of stuff!
Welcome to the forum.
rod81
Aug 12, 2010 10:51 PM
