P2135 no start just crank what do I do
Old Mar 14, 2019 | 09:54 PM
Jboyskulls's Avatar
Default P2135 no start just crank what do I do
I have a 2005 jaguar s type v6 and now it won’t start it’s throwing a p2135 code the throttle body sensor is not working I took the throttle apart and cleaned the inside and the gear spurs put it back together cleared the codes tried to start it but same thing as before crank but no start I’ve tried so many times and charged the battery and everything please helpppppppp
Old Mar 15, 2019 | 06:12 AM
JagV8's Avatar
It should start regardless of the code so you are in a "crank but no start" where the code is not the issue.
If you hunt around I think there's a Jaguar PDF about that.
There's also detailed info about all the causes of that code. I gather sometime around your car's era it had two meanings - one for the TPS1/TPS2 and the other for APP1/APP2. I think yours is the former but note it can be wiring etc. (Read the Jag doc!)
45Wheelgun
30
Apr 16, 2014 03:08 AM
jahummer
26
Oct 31, 2011 10:40 PM
45Wheelgun
Oct 5, 2011 03:44 PM
brian
Apr 15, 2010 02:38 AM
