PARK BRAKE Fault S-TYPE R
Old Mar 27, 2021 | 11:13 AM
turkay's Avatar
Default PARK BRAKE Fault S-TYPE R
Hey guys,
i started to disengage the parking brake on my Jaguar S TYPE R 2004 (December Model) my parking brake was left like that disengaged for about 7 days, but now I can no longer engage it and the thing that bothers me the most is that I get the PARK BrAKE Fault in my dashboard along with the ABS light, I took the battery out from the car and charged it for 1 day and then when I put it back on the problem still persists. I noticed that my brake pedal is much easier to press now compared to back then, it’s to soft feels spongy. I did try and reset it a couple of times by removing the battery terminals for 30-60 minutes, but nothing. Still the same problem, at least I can drive it. But the awful part is that I am short on income at the moment and I can’t take it to a shop. Any idea what might had caused it? Did they seize by rusting a bit while it was disengage, i need to mention that it was really rainy the past days. Any tips anyone faced it before? The park brake atarted giving me some headaches since January because of the cold weather.
Old Mar 27, 2021 | 04:03 PM
M-e-l-l-o-w's Avatar
Is your car a 05-model year 'facelift' car that were made from January 2004, or a 04-model year car made in 2003?
You can tell but looking that the 10th digit in the VIN number 5 = 05 model year, 4 = 04 model year.
The parking brake is totally separate from the foot brake.
Mellow
Old Mar 28, 2021 | 08:41 PM
turkay's Avatar
Mellow
Hello, this is the VIN Number: SAJAA03S741N07607
and yeah I looked a little into it and found out that the Park Brake is enabled by a small motor.
Old Mar 29, 2021 | 02:05 AM
JagV8's Avatar
Appears to be at least 2 separate, unrelated, faults. Possibly also ABS (read its codes!), making a 3rd.
Old Mar 29, 2021 | 02:10 AM
turkay's Avatar
My bad it isn’t the ABS Warning Light, it’s the Brake Pads Warning Light that always stays on (but disappears after a battery reset) and the only thing that pops and flashes for a bit until I put the car in gear is the Park Brake, I have to hold down the switch along with the brake when I close it so it doesn’t beep like hell.
Old Mar 29, 2021 | 04:38 AM
Your car is an 04 model year car, it would have been made in 2003.
The facelift 05 model year cars started at vin N14071, with productrion starting in January 2004 after the Christmas shutdown.
As mentioned above you have two faults. Have you looked to see if you have any fault codes? You will need a fault code reader, or the jaguar IDS software to view these.
Old Mar 29, 2021 | 09:10 AM
S-Type Owner's Avatar
To add to Mellow's comment above, you will need a code reader that is capable of handling Jaguar chassis/module codes, not a basic OBD-II unit; an example of this is the iCarsoft i930, or LR-II/2.0 .
coachdrew21
Apr 28, 2019 01:18 PM
krssubbu
Mar 3, 2017 08:31 AM
wizardsrule
Feb 17, 2014 10:06 PM
Walter Brooks
19
Dec 29, 2013 08:38 AM
climberman
Dec 16, 2010 12:41 PM
