Part # confusion
Old May 18, 2024 | 04:07 PM
scrannel's Avatar
Default Part # confusion
Ok, chasing a P0456 and finally pulled the engine cover on my 2008 NA 4.2 to check the purge valve. First glance purge valve looks brand new -- even has the part# tag. But... I thought I'd run the part # (AJ811242) and I keep getting "this part is not compatible with your car." Apparently, it's for an F-Type? The engines seem so close, is it true it is not compatible? Thanks
Old May 18, 2024 | 04:13 PM
NBCat's Avatar
The X152 uses the AJ133/AJ126, which are different.
Check this link from SNG Barratt, one of the forum sponsors:
https://www.sngbarratt.com/English/#...%60AJ811242%60
Old May 18, 2024 | 04:24 PM
scrannel's Avatar
Using # AJ811242 I keep getting "it won't work". Only SNG Barratt says it's right. For instance:
2007-2010 Jaguar Vapor Canister Purge Solenoid AJ811242 | JaguarParts.com
2008 Jaguar S-Type 4.2L V8 A/T Base Sedan Vapor Canister Purge Solenoid - AJ811242 | Jaguar Palm Beach, West Palm Beach FL
Old May 18, 2024 | 08:45 PM
xalty's Avatar
yes the xf 4.2 part is the same
Old May 18, 2024 | 09:01 PM
scrannel's Avatar
Thanks, you all!
AlexE
Jun 5, 2023 11:07 PM
Anbran
Apr 29, 2023 09:09 PM
Barry Leftwich
Sep 19, 2020 03:43 AM
sidescrollin
May 9, 2018 07:47 AM
Oldengineer
Apr 11, 2009 03:48 PM
