Passenger door
Old Mar 2, 2014 | 03:53 AM
koolmanpete's Avatar
Default Passenger door
Jaguar s type 3.litre 2004 75000 miles.
Rear passenger door wont unlock with remote,also wont open manualy from inside or out.
Old Mar 2, 2014 | 03:56 AM
I've moved your question from UK Region to S-Type forum. The model tech section is the place to get answers to this type of question.
Members here with the same model will be able to help.
Old Mar 2, 2014 | 06:11 AM
Not sure what is happening been transferd to uk then back to s type.
Old Mar 2, 2014 | 06:17 AM
Whenever I move a thread, I always leave a redirect from the original location or the poster will never find it again.
In this case, I moved your thread from UK to S-Type forum leaving a redirect in UK forum. If you click on it there it brings you directly to this thread location.
More importantly, let's see if anyone can tell you how to open the door!
Old Mar 2, 2014 | 09:44 AM
JagV8's Avatar
Thumping at the right moment might work but otherwise - someone's done it before and it's not wonderfully easy or nice. Search on here or it may have been the UK-based forum. Quite detailed info was posted.
Old Mar 2, 2014 | 12:21 PM
joycesjag's Avatar
Here ya' go:
https://www.jaguarforums.com/forum/s...ics-faq-65657/
Old Nov 23, 2014 | 12:22 AM
jobrien3's Avatar
Question Locked Rear Door
Hi , I have read about how to repair the rear door lock however I am still unsure of how to get the door unlocked so that I can do the work?
Jim
Old Nov 23, 2014 | 03:27 AM
Paul792's Avatar
I looked this up on another site.
"You need to remove the rear seats then you can try to pull of the panel to release the latch. The latch assembly will most likely need to be replaced. Fold down the rear seat then there is a black lever you need to move and the top of the side seat will come out then you can pull out that side seat bolster. To remove the door panel remove the inner handle cover then remove the black screw cover in the panel pull handle. Remove the two Phillips then the panel can be removed carefully"
"Once you fold down the seats the lever is on the top of that side bolster. These are the same as the bottom"
The link to the quote above is here: http://www.justanswer.com/jaguar/6h8...-open-how.html
This is a theoretical answer, for me, so I have not used this advice but I hope this helps you out.
Old Nov 23, 2014 | 08:37 AM
tony1963's Avatar
Removing the door panel with the door closed is one of the hardest jobs to do without messing up the door panel. It can, however, be done. Just be patient and follow the instructions shown above.
kevinl
Oct 31, 2019 06:15 PM
r111ynf
Sep 20, 2015 09:42 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
UalCapt
Sep 14, 2015 01:42 AM
avern1
Sep 8, 2015 06:25 PM
