PCM Continuity tests
Old Aug 8, 2012 | 04:11 PM
Leonard_85's Avatar
Default PCM Continuity tests
Hello all,
I'm following JTIS steps on Solenoid SSA/B/C/D continuity tests on CONNECTOR GB5 against PCM GB1.
Before removing PCM CONNECTOR GB1, should the battery be disconnected?
Has anyone had problems after unplugging their PCM connectors, i.e. security, engine immobilised...??
Regards,
Old Aug 8, 2012 | 04:50 PM
JagV8's Avatar
I'd disconnect at the battery. Once it's off you can't get security/etc issues as there's no power! (Whereas leaving it connected is a risk of shorts etc.) They have to be built to cope with no battery as it's a normal occurrence.
Afterwards, you'll have to reset the one-touch windows and either input or bypass any radio code.
Old Aug 10, 2012 | 08:23 AM
Leonard_85's Avatar
JagV8,
Thanks - testing performed successfully. Continuity correct.
D/C Battery - removed GB1 PLUG. Reconnected battery.
To reach PCM remove windscreen cowl, air filter (4 nuts) and plastic relief-tray beneath (3 nuts). See image.
For anyone's reference, i've attached the data sheet we used since JTIS method produced zero results.
This was really simple - just D/C fuse 106 (15 Amp) on Front Distribution Box and test between output and GB1 plug (1 metre apart). This saves you from crawling beneath vehicle to remove Transmission Plug GB5 - Nightmare.
I'm safe in the knowledge my electrical components are sound which leads me to a faulty PCM or internal damage.
Or the fact we now think the engine is loosing pressure. Next.
File Type: pdf
Old Aug 10, 2012 | 10:08 AM
JagV8's Avatar
The few we've heard with damage had clearly had water getting in - something easily seen. They don't seem to go bad otherwise. BTW, you can't just swap another in as the anti-theft will kick in big-time.
Sorry to hear about the pressure issue!
Old Aug 10, 2012 | 12:15 PM
tbird6's Avatar
Heed what JagV8 said. The PCM almost never fails.
The one or two documented cases were from water getting into the PCM. Have you pulled the PCM/ECM to just have a look for corrosion? It's not that easy to get out but I would do it before getting another one.
Old Aug 12, 2012 | 02:59 AM
Leonard_85's Avatar
Yes, immediately noticed spider-webs and the area covered in a fine dust - no water has been there (even though previous owner had a 3-headed-dog fit the windscreen - finger gaps on seal). There's also an angled aperture surrounding plugs.
The relief-tray also has fibrous backing to "sponge" any stray water - quite a neat touch.
For a spare hour, this test is definitely worth health-checking electrical transmission components.
Jagv8, we think the IMT Seals have gone, expect a post soon i guess.
Rivguy
Nov 13, 2022 02:55 AM
JWheeler
Nov 22, 2019 08:28 AM
kaotikd
40
Nov 4, 2015 12:54 PM
Tipptone
Sep 16, 2015 07:39 AM
XFR_Gold
Sep 2, 2015 12:24 PM
