Performance Air Intake
Old Dec 21, 2022 | 08:15 AM
Car Crazy's Avatar
Default Performance Air Intake
I am thinking of purchasing the performance air intake kit with the polished stainless steel tube and K&N cone filter from Mina Gallery. Does anybody have this setup ? If so your thoughts. Thanks...
Old Dec 21, 2022 | 08:52 AM
JagV8's Avatar
Is that the hot air intake?
Old Dec 21, 2022 | 09:14 AM
Car Crazy's Avatar
The stock air filter box is replaced with an open style K&N cone filter. I don't know if that is a cold or warm air intake.
Old Dec 21, 2022 | 09:40 AM
S-Type Owner's Avatar
You haven't indicated which model/engine you are wanting to "upgrade". Adding your model/engine/production year to your signature line helps us to help you...
I suspect the "hot air intake" remark was a bit tongue-in-cheek, as that is what you will get with the combo you are suggesting. Well, that and K&N oil coating the inside of your intake system, MAF and throttle body...
Old Dec 21, 2022 | 10:36 PM
Car Crazy's Avatar
It is a 2006 S-Type R
Old Dec 22, 2022 | 03:51 AM
Datsports's Avatar
go with the Mina Gallery kit.
its around 7-10 hp gain with a true cold air partition panel . ( if ) you put radiator foam in the rite places .
the J-Pipe you see is custom . .
i believe there is more power to be unlocked by replacing the flat black intake elbow across the top of the engine with the range rover one . someone on here has posts about this .
Ashton Dimovski
Mar 14, 2022 12:53 PM
dtk
Dec 26, 2020 05:41 AM
Pacio
Mar 2, 2012 02:33 PM
Vipercf
Mar 2, 2010 03:30 PM
johnny_kiu@yahoo.com
General Tech Help
Dec 14, 2009 02:55 PM
