Performance Catalytic converters and x pipe
Old Sep 18, 2019 | 06:38 AM
Aarcuda's Avatar
Default Performance Catalytic converters and x pipe
Whats a good high performance catalytic converter for my 06 STR?
I need new cats and an x pipe
Old Sep 18, 2019 | 06:40 AM
Aarcuda's Avatar
Look
Old Sep 18, 2019 | 12:00 PM
S-Type Owner's Avatar
Wow... that is some pretty poor welding! There is a gap where the spliced in section joins the exhaust pipe on the downstream side of the converter.
What a bodge job that is! Given the mis-match is diameters and sloppy welding, a re-do certainly seems a reasonable approach. You might want to contact "frankc" over on the British Jaguar forum and see what brand of 40 cell cats he had installed on his XK-R.
Old Sep 18, 2019 | 07:56 PM
Aarcuda's Avatar
Totally boogered. Im not a great welder but I can do better than that! I decided upon this: MagnaFlow 59975 Universal Catalytic Converter (Non CARB Compliant)
Amazon Amazon
want to get new o2 sensors too. Im getting lean codes and hear the exhaust ticking so im pretty sure theres a leak
Old Sep 19, 2019 | 11:58 AM
Originally Posted by Aarcuda
Totally boogered. Im not a great welder but I can do better than that! I decided upon this: MagnaFlow 59975 Universal Catalytic Converter (Non CARB Compliant) https://www.amazon.com/dp/B000XQM3O2..._xdTGDbRMXP4HM
aarcuda: The pictured catalysts do not appear to have the threaded boss to accept installation of an oxygen sensor. Is this correct?
Old Sep 19, 2019 | 07:23 PM
Datsports's Avatar
Correct you have to drill and fit your own threaded bosses ,
i went with those cats ,
beware they only last around 1 year 15000km on a STR ,even with neer perfect AFR and fuel trims they melt.
I’ve now had two sets of them and melted both ,
i ended up gutting them and sleeving them , for reliability,
magnaflow Actually has a Bolt ON SET for the STR
NOW ,
maybe that might be better
Old Sep 19, 2019 | 07:32 PM
AlexJag's Avatar
Sponsor
NOW ,
This was 200cel magnaflow in less than 7500 miles
I have to agree the welding and especially the mismatch in diameter is horrible. Might actually be loosing power with that bottle neck
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Sep 20, 2019 | 02:05 AM
Datsports's Avatar
Yep this was mine after only 10000km
Old Sep 20, 2019 | 03:11 AM
XJR-99's Avatar
I would use just HIGH quality catalysts. Larini ( my X308 XJR ) or HJS .
Old Sep 20, 2019 | 02:41 PM
AlexJag's Avatar
Sponsor
What brand did you have?
Old Sep 20, 2019 | 02:45 PM
Aarcuda's Avatar
NOW ,
Crap are you serious? What causes them to do that? These things arent cheap! And I dont want to go welding on them and have em fail and be **** outta luck.
Dammit. They are being delivered today. Maybe I should just return em and get a stock set of cat pipe from davico or pacesetter (any suggestions on whats best?
Old Sep 20, 2019 | 02:47 PM
Aarcuda's Avatar
Well if im only going to get a year or two out of them I definitely will.
I had a set of hi flow cats on my challenger and they lasted quite some time 4 years until I traded it). I wonder what they used. But those cats were after long tube headers. So they were further back from the heads
Old Sep 20, 2019 | 04:22 PM
Datsports's Avatar
magnaflow 200 cell 59975 .
Old Sep 21, 2019 | 02:21 PM
Aarcuda's Avatar
So the cats came in yesterday. Ya. Im returning them. They are the smallest cats ive ever seen! Maybe 7” long body? Thats tiny! No way im gonna use these. They look like theyre for a motorcycle
Old Sep 21, 2019 | 06:04 PM
AlexJag's Avatar
Sponsor
All aftermarket are small like that. What brand did you buy? Here is what my look like. I did test the flow and they do outflow stock by a big margin, but the issue is quality and they didn't last, even though my Afr ratio was set perfect and much better than stock was.
Old Sep 22, 2019 | 03:39 AM
XJR-99's Avatar
Old Sep 23, 2019 | 07:40 AM
Aarcuda's Avatar
I got the magniflows
MagnaFlow Exhaust Products MagnaFlow Exhaust Products
2.0 out of 5 stars  1Reviews 2.0 out of 5 stars 1Reviews
Old Sep 23, 2019 | 08:05 AM
jackra_1's Avatar
Thats what I have had for the last 7,000 miles.
Initially used the "mini cat inserts" to hold O2 sensors but they caused big smoking problems under acceleration so just put O2 sensors directly in place of mini cats with no issues at all.
Old Sep 23, 2019 | 09:01 AM
XJR-99's Avatar
Mine have been fine since 2011. I guess Avos uses same catalysts and his car has run huge amount of miles. Not sure if he still have first sets of those sports cats.
Old Sep 23, 2019 | 10:00 AM
Aarcuda's Avatar
So you and Avos are running the same magnaflow 55975 cats that I bought?
Im confused why they pics of the failed units look like something collapsed the interior parts..... it looks like something mushed the plates over. These cats have a 3 year warranty I believe. For the ones that failed, Did you try to get them warrantied?
